Author Topic: A newbie question - which varnish/oil?  (Read 3103 times)
cuppa
« on: October 01, 2011, 02:20:19 pm »
Please pardon my ignorance but I am uncertain as to the best finish to apply to wood that is in close proximity to a steam plant.........
Any advice will be gratefully recieved.
Many thanks
                  Jon
Re: A newbie question - which varnish/oil?
« Reply #1 on: October 01, 2011, 02:43:31 pm »
Hullo Jon....
If we are talking about our typical model marine steam plant........the  >>:-( highest temperature of the boiler casing or steam discharge line is in the order of 150 degrees C  :P ....however these can be lagged to retain heat & minimise the effect on other components
You need an adaquate air circulation/corridor between steam components ..... & the wooden hull structure
Varnish?..... <*<... even the modern polyurathane spray or brush on products are limited to ~~~~~~~80 degrees C
Why not post an image of the plant in the hull....... :-)) Derek
cuppa
« Reply #2 on: October 01, 2011, 03:28:37 pm »
Hi Derek
Sorry - I did not explain myself very well in my first post. I was wondering what finish would work on the bearers that mount the steam plant to the hull. I have a cheddar steam plant that sits on a brass tray. I was planning on mounting this tray on to wooden bearers and was wondering how best to apply a sealing finish to the bearers?
          Jon
NickKK
« Reply #3 on: October 01, 2011, 03:42:22 pm »
Engine Laquer might be more of a reliable coating ... I don't know for sure if it would be suitable ?  But it is a high temprature varnish for petrol engines.
Nick
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
« Reply #4 on: October 01, 2011, 05:42:05 pm »
'Le Tonkinois' varnish resists boiling very well so would resist what little temperature the bearers will get.
Greg
cuppa
« Reply #5 on: October 01, 2011, 06:16:34 pm »
Thanks Greg
          Jon
HS93 (RIP)
  • I cannot spell , tough
« Reply #6 on: October 01, 2011, 11:47:39 pm »
Cheddar models used polyurethane for years on there boiler lagging touching the boiler so I think it should be fine as a coating for some bearers under the brass plate.
Peter
cuppa
« Reply #7 on: October 02, 2011, 06:43:33 am »
Thanks Peter
I will follow Cheddar's lead.
          Jon
Page created in 0.597 seconds with 17 queries.
