Author Topic: Where can I get this Hose?  (Read 5610 times)
HS93 (RIP)
  • I cannot spell , tough
« on: March 17, 2007, 01:25:45 am »
I'm after some of this type of hose for my boat, I've seen it on many steam projects but cannot find out where to get it from. I need about 5/16 dia but 3/8 or there about will do,
thanks  Peter
boatmadman
Re: Where can I get this Hose?
« Reply #1 on: March 17, 2007, 01:54:28 am »
Can you give us a clue?   ;D
HS93 (RIP)
« Reply #2 on: March 17, 2007, 02:29:59 am »
sorry about that, but the photo did not come out very well, and as you cannot remove the topic I had to go and find a better one .Peter
RickF
« Reply #3 on: March 17, 2007, 11:11:04 am »
Peter,
Just a thought, but I'd try a washing machine repair shop.
Rick
boatmadman
« Reply #4 on: March 17, 2007, 12:35:44 pm »
Or a caravan accessories shop
RickF
« Reply #5 on: March 17, 2007, 12:49:23 pm »
Yes, Ian, now I remember where I bought some years ago. It was for the sink drain on a boat (full size) and was available from caravan/camping shops and from boat chandlers.
Rick
« Reply #6 on: March 17, 2007, 12:56:08 pm »
Hi there Peter,
Is the piping you require actually going to be used to pipe fluid?  If not, I have used, in the past, I have used net curtain wire (the stuff you hang the nets up with) If you cut your length of wire and gently warm that over an open flame it corrugates it more.   If that isnt the correct diameter what I would so next was wrap string around the outside of the curtain wire and then covered that with electricians' heat shrink and that gives a good effect.   If it would help I can post a diagram  8) and before our DickyD says anything - we have glass in our windows up North with no iron bars across them  ::) ::)
just re-read your opening post Peter, and Im having a bad day - have you thought of what they use on the automatic outlet pipes for automatic washing machines and that sort of product.   aye its this cold getting to me!!!
aye
John E
BLUEBIRD
« Reply #7 on: March 17, 2007, 01:13:42 pm »
If it is small diameter, I got the hose off one of those cheapo airbed footpumps.
There is also the flexible copper pipe you get for plumbing jobs.
riggers24
  • Just full of stupid questions
« Reply #8 on: March 17, 2007, 01:33:05 pm »
If the hose doesn't carry fluid, try a spring covered with heat shrink
I will finish the crash tender someday - Still got tooo many toys to play with
HS93 (RIP)
« Reply #9 on: March 17, 2007, 01:50:17 pm »
That looks good riggers  I think you know what it's for , the suction hose on the crashtender , they don't have to take water, so that looks good in that I can find some springs and some shrink.. Thanks to all that came back. Peter
« Reply #10 on: March 17, 2007, 02:10:29 pm »
Washing machine hose is too big John.
Richard ;)
HS93 (RIP)
« Reply #11 on: March 17, 2007, 02:22:29 pm »
Riggers, where did you get your springs ?
Peter
Peterm
  • Inactive
« Reply #12 on: March 17, 2007, 02:52:54 pm »
Wells?
I`m not just old, I`m ancient
« Reply #13 on: March 17, 2007, 03:02:29 pm »
I used to live just down the road from there. ;D
Bunkerbarge
« Reply #14 on: March 17, 2007, 08:47:15 pm »
Check out electrical wholesalers for flexible conduit.  Comes in all sorts of diameters and you can buy it by the length at the good outlets.
andywright
« Reply #16 on: April 09, 2007, 07:15:55 pm »
Try a water garden shop/centre. They stock the stuff for pond filters, I have seen some small dia. but don't know how small it goes.
andywright
« Reply #17 on: April 18, 2007, 09:43:40 pm »
HS93, Have seen the identical hose, Have sent you a pm
HS93 (RIP)
« Reply #18 on: April 18, 2007, 09:59:26 pm »
Thanks for that Andy.  sent you a PM.
Peter
HS93 (RIP)
« Reply #19 on: June 05, 2007, 08:38:45 am »
I used the method  riggers24 suggested and hear are my efforts, the one on the picture was finished when I decided to take a skim of the pipe end  $£&****  for an hour or so and start again.
riggers24 are you still building your fire boat? if so I may have some think for you.
Peter
