Started on the electrics, the power to all will be
Flightpower EON X lite, 2100mah, 3s, 25C lipo and weighs only 169g
Iv modified it by adding rx plug soldered on with the 3mm bullets,this will go to a switch then to the 5A UBEC then to rx, but should make for long run times without having to worry about the rx pack failing
The steering servo is 1/5 21kg MG high torque digital servo
The throttle is 9kg,standard size,MG high torque digital servo (abit over kill i know but will do for now for testing)
Throttle servo will be connected to failsafe in the event of a failure
Radio is Flysky TX & RX also installing a voltmeter to rx
