Pages: 1 2 3 4 5 [6] 7   Go Down
Author Topic: 46" Gas F1 Tunnel 2011 build  (Read 52016 times)
Danny
  • Gorleston Model Boat Club
    • Gorleston MBC
Re: 46" Gas F1 Tunnel 2011 build
« Reply #125 on: May 19, 2012, 08:31:52 pm »
Bummer - that's got bad!  I see they were there on the 15th (first two shots) but look as though its got a lot worse.
Hope you can get it redone for Nottingham.
Maybe its allergic to water??  %)
Danny
F1 madness
« Reply #126 on: May 19, 2012, 08:54:42 pm »
Hi danny
LOL its been like it a for a few weeks now but didnt know really what to do it leave it as it is or repaint it
but i dont want it shown like this so repaint it is should have it sorted next (i hope) LOL
But something else has come to my attention now about the K30's so looks like an engine rebuild aswell so luck is not on my side at mo <:(
F1 madness
« Reply #127 on: May 20, 2012, 12:22:31 pm »
Iv also pulled the motor apart after being warned of the wrist pin spacers breaking up
So iv added the 1mm stroker crank,drill and tapped a nipple for external pulse for the bigbore carb if i need it
Hopefully sorted out and having piston machined to use the zenoah wrist pin spacers
When i added the bigbore carb i noticed the inlet port had a lip along the bottom and 1 side so iv also carefully filed it away and profiled it so it matches the ISO block for better flow
better matched the crankcase transfer ports to the cylinder jug so hopefully see some improvements once it back together
The hull should be reprimed tomorrow and need to go and order my race number vinyl aswell
Made the grab handles using 4mm plastic coated stainless steel wire wit eyes on each end crimped and silver soldered with a small piece of heat shrink on and drilled the holes ready to fit so havnt got to do it once painted
the handles themselves look pretty good just not easy to do on the F1 style hull but rules are rules
Will post some pics soon
martno1fan
« Reply #128 on: May 20, 2012, 12:29:06 pm »
Hope you only drilled and tapped the iso block not the crankcase much simpler  :}.
Mart
scoop
« Reply #129 on: May 20, 2012, 12:53:57 pm »
Hi Daz,  you can get vinyl race numbers from most DIY stores or ironmongers, about 50p each, don't forget your class ID either in your case the letter D.
I know our rules state 50 mm high letters/numbers but I use 75mm one's, much easier for the lapscorers to see  :}
Scoop
ps Good luck with the repaint  :-))
BMPRS Secretary/Pro www.bmprs.co.uk
PS. There ain't no going back
F1 madness
« Reply #130 on: May 20, 2012, 01:08:35 pm »
Mart had to drill and tap the crankcase so did it while it was apart only took 5mins to do cos of the iso block on the rear exhaust engine,i had to remove some material/mod the iso block to clear the flywheel aswell but its all done and dusted
just need the piston and spacers sorting now,also iv ordered a pipe aswell while sorting a proper 1 from the man (you know who) just not sure on the time scale yet
Hi scoop will get them bigger and didnt forget the D  :-))
Just hope things go to plan to make it in time another problem is im gonna have to run it in again aswell :((
F1 madness
« Reply #131 on: May 20, 2012, 04:57:08 pm »
Got the the bottom end back together now,fitted the 1mm stroker
matched the crankcase transfer to jug ports,i did do it before just made them match better and drilled and tapped the crankcase for nipple for the external pulseline if need for the carb but might just run it anyways,also matche the ISO block to inlet port on jug aswell,had to trim the teflon gasket aswell but looks much better now
and made a bracket to support the ignition coil due to adding the nipple in the crankcase
F1 madness
« Reply #132 on: May 21, 2012, 10:12:31 am »
Hull now down the paint shop for barcoat and primer and baked should have it back later today  %)
scoop
« Reply #133 on: May 21, 2012, 12:46:05 pm »
Hi Daz, you could always use the race as a running in session if you are pushed for time, lat east that way it will give the rest of us a chance to get a few points  {-) {-) {-)
Scoop
F1 madness
« Reply #134 on: May 21, 2012, 03:59:58 pm »
Hi scoop
LOL what you trying to say  :}
Just went down to pick the hull and they not done it so gonna be tomorrow afternoon before i get it back :(( and not heard back about the other stuff either so at this rate its not gonna be ready
F1 madness
« Reply #135 on: May 22, 2012, 09:24:12 pm »
Engine is now all finished up and ready to fire up again once the the hull returns from paint shop,hopefully picking it up thursday all fresh n shiny again,the items i ordered should be here in the next day or 2 aswell so will have a couple of days to hopefully get it back together setup and fire it up
F1 madness
« Reply #136 on: May 23, 2012, 11:28:18 pm »
Hi all
There was a change of plan ended up painting it myself  so lots of hrs work later and drying time here it is its new paint its not 100% but she does look alot better than before
Plenty left to do yet reinstalling everything and getting it all setup and firing up the engine for the 1st time again
More pics soon
gwa84the2nd
« Reply #137 on: May 24, 2012, 02:09:30 am »
that looks sooooooo much cooler in white  :-))
Andyn
« Reply #138 on: May 24, 2012, 07:57:57 am »
Yes, I don't usually like white boats but that looks awesome :-))
martno1fan
« Reply #139 on: May 24, 2012, 08:01:07 am »
Cant beat white boats they just look awesome with some nice bright decals  :-)).
Mart
F1 madness
« Reply #140 on: May 24, 2012, 08:19:38 am »
Thanks guys
im alot happier with now for defo still a fair bit to yet before sunday  :-))
F1 madness
« Reply #141 on: May 24, 2012, 07:03:04 pm »
Build is complete and looking good again
Added some stainless scoops either side to help with cooling and feed air to the bigbore carb
Tomorrow will connect to the hose pipe in the garden fire it up and make any adjustments needed
scoop
« Reply #142 on: May 24, 2012, 09:22:47 pm »
Mart
I'm with you on that one mart, by the way the Navaho build for Model Boats mag is finished at long last  :} White boat, simple graphics, easy to repair   :-))
Scoop
Danny
    • Gorleston MBC
« Reply #143 on: May 24, 2012, 10:12:32 pm »
That's a really nice boat Darren.  Should be a great debut on Sunday - sunny and not too much wind.  Perfick!!
Danny
F1 madness
« Reply #144 on: May 24, 2012, 10:20:41 pm »
Thanks  danny
lets just hope it fires up ok tomorrow,could really do with taking down the pond for a run before hand and see how it is,if its anything like the 1st time i run the this engine it wont get very far LOL {-)
but ill fire it up in the garden with the hose pipe attached and see what happens 1st
F1 madness
« Reply #145 on: May 25, 2012, 10:42:43 am »
Got it fired up after 6 pulls,sounds ok so far got a nice throttle tone to it
Only issue is it seems too rich and got abit of over run once you let go of the throttle trigger,youll notice at the end of the vid starts revving up by itself so some adjustment is needed
Cant wait to run it properly and see how really performs
http://www.youtube.com/watch?v=QE941sx01kI
patternmaker
« Reply #146 on: May 25, 2012, 04:28:35 pm »
What a great build, its going to be a very quick boat, well done.
Mick
Failure is not an option
F1 madness
« Reply #147 on: May 25, 2012, 06:17:33 pm »
Thanks mick
Hope so LOL  :-))
will find out soon and ill get some vids  :}
F1 madness
« Reply #148 on: May 29, 2012, 02:25:30 pm »
Finally managed to get it on the water and ill let you guys be the judge
heres some pics i snipped from the vids
The vids are uploading now will post once finished
sorry about the quality of the pics
F1 madness
« Reply #149 on: May 29, 2012, 04:08:06 pm »
vids of run 2 & 3 have uploaded having trouble with vid of 1st of run so will post that laters
2nd run
http://www.youtube.com/watch?v=1BJAAQJSWcg
3rd run
http://www.youtube.com/watch?v=wgBhiieJF3w
Pages: 1 2 3 4 5 [6] 7   Go Up
Page created in 0.093 seconds with 22 queries.
