January 24, 2021, 09:22:38 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Mayhem also on Facebook!
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Tugs and Towing
prop shafts
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: prop shafts (Read 2782 times)
Gerryg
Guest
prop shafts
on:
October 14, 2011, 03:49:05 pm »
Hi being new to building boats I was just wondering if anyone can answer a question for me when using a fibre glass hull how do you seal the prop shaft from the water. I know in a real ship you have a packed gland is it the same on a model boat ?
Full Mayhemer
Offline
www.srcmbc.org.uk
Southampton UK
Re: prop shafts
Reply #1 on:
October 14, 2011, 03:55:43 pm »
For sealing between prop shaft and hull use two part epoxy resin.
I use Zap Z-Poxy 5 Minute Formula 8oz Set
http://www.cornwallmodelboats.co.uk/acatalog/epoxy_glues.html
To seal larger gaps use P38 car body filler or even larger gaps use P40 car body filler available from Halfords
Richard
Solent Radio Controlled Model Boat Club
http://www.srcmbc.org.uk
Gerryg
Guest
Re: prop shafts
Reply #2 on:
October 14, 2011, 05:01:05 pm »
Thanks for the info Richard so the shaft just runs in the drilled hole do you need to lubricate the shaft as it's runnig on the bear fibre glass ?
BlueWotsit
Full Mayhemer
Offline
Ilfracombe, North Devon
Re: prop shafts
Reply #3 on:
October 14, 2011, 05:07:27 pm »
Im wondering if theres a misunderstanding here.
You usually have an outer shaft which is bonded into the hull in the manner described.
Inside this outer shaft / tube is the running part of the shaft which is usually watersealed and lubricated using various types of grease - personally I use the green gunky grease thats used on bicycles for lubricating gears - this is an ideal silicone based lubricant
Full Mayhemer
Offline
SW Surrey, UK
Re: prop shafts
Reply #4 on:
October 14, 2011, 05:24:02 pm »
There is a huge amount of advice on the forum about prop shafts if you use the search facility from the main forum page.
Use keywords such as propshaft, prop shafts, oiling etc.
Gerryg
Guest
Re: prop shafts
Reply #5 on:
October 14, 2011, 09:28:35 pm »
Thanks guys I have got it now so the prop shaft runs inside a bush glued to the hull !
Full Mayhemer
Offline
SW Surrey, UK
Re: prop shafts
Reply #6 on:
October 14, 2011, 09:34:35 pm »
Not quite!
The propeller shaft runs in a tube fitted with bushes at each end which is fitted and glued into the hull. Some form of lubrication is then used within the tube although nobody can agree what is the best type!
Full Mayhemer
Offline
www.srcmbc.org.uk
Southampton UK
Re: prop shafts
Reply #7 on:
October 14, 2011, 09:50:44 pm »
Photos of some prop shafts.
http://www.cornwallmodelboats.co.uk/acatalog/Raboesch_Precision_Propshafts.html
Richard
craftysod
Guest
Re: prop shafts
Reply #8 on:
October 14, 2011, 10:12:21 pm »
A very rough drawing of what they do
Mark
pugwash
Guest
Re: prop shafts
Reply #9 on:
October 14, 2011, 11:58:20 pm »
Gerry it is also possible (depending on the type of ship) to fit the propshaft at an angle so the inner end is above the water
so that you only need a small amount of oil for lubrication only - this is quite common on warship models.
Geoff
Gerryg
Guest
Re: prop shafts
Reply #10 on:
October 15, 2011, 09:26:05 am »
Thanks all got it now.
Print
Pages: [
1
Go Up
« previous
next »
Tugs and Towing
prop shafts
