Author Topic: Float Switch  (Read 3061 times)
Tugger
Float Switch
« on: March 18, 2007, 09:44:05 pm »
does any one have a design for float switch to activate a bilge pump. After my recent exploits at Balne Moor I think I need one. ???
norry
Re: Float Switch
« Reply #1 on: March 18, 2007, 09:59:11 pm »
   ...Hi Guys...
There is a pressure type switch in a washing machine that could be adapted for a model boat...
My father adapted one a few years ago for a full size fishing boat...
It might be a bit on the big side for "RASCAL" but should fit a lot of the bigger boats...
It might be worth having a look into...But dont be nicking the one out of her indoors current washing machine or it could be an expensive move...
              ...All The Best...Norry...
Tug
Re: Float Switch
« Reply #2 on: March 18, 2007, 10:03:59 pm »
What you are looking for is a mercury switch,  tilt to go
 its a small glass bubble like a LED with a ball of mercury inside to make the contact might need a relay cause they are small,
don't know where I got mine it was so long ago.......
Junk is something you've kept for years and throw away three
 weeks before you need it.
omra85
Re: Float Switch
« Reply #3 on: March 18, 2007, 10:21:55 pm »
I don't think they're allowed to use mercury nowadays, but I have seen one with a small ball bearing in a sealed tube.
How about a simple microswitch with an extension on the actuating arm, onto which you could fix a cork?? Cork lifts, switch switches, water goes down, cork drops, switch disconnects.
Told you I was simple ;D
Danny
Re: Float Switch
« Reply #4 on: March 18, 2007, 10:27:12 pm »
bobdoc
Re: Float Switch
« Reply #5 on: March 18, 2007, 10:30:16 pm »
Try Hunter Systems:
1) Eco-Pump Switcher: This unit when connected to a pump and a DC power source will sense if water seeps into the Model. The unit will then activate the attached pump and this will empty any ingress of water in the model.
2) Submersible Pump A low cost 6 volt water pump suitable for a wide range of project applications - from automatic watering systems to water jet boats. It is also very compatible with the Eco-Pump Switcher for just pumping water as a Bilge Pump. Size is 60mm high and 30mm dia. Weighs 35g The pump is sealed and can safely be fully immersed in a water reservoir. It is supplied with a length of plastic tube that can be used to direct the flow of water.
Both at http://www.huntersystems.co.uk/
Bobdoc
ministeve
  • washing the decks!!!
Re: Float Switch
« Reply #6 on: March 18, 2007, 10:59:44 pm »
was wiggy there at the washout at Blane if so try and ask him about his bilge pump control box its very good myself and poll have one. i think you can find him on hear or i will ask poll for his number and pm you if there is no probs
Tugger
Re: Float Switch
« Reply #7 on: March 19, 2007, 01:15:19 pm »
Yes he was at Balne we were talking about float switches and asked him for the design. But after my tug turned turtle and the other lost it's prop I forgot about it. so if you could pm his email or ask him to send me details that would be great.
catengineman
Re: Float Switch
« Reply #8 on: March 19, 2007, 07:31:46 pm »
 Maplins do a kit to construct a moisture detector which I am sure could be altered to control a small pump, The only problem I can think of is priming said pump unless it was a good make and had a self priming action. most of the smallpumps I have taken apart have been a simple paddle type but a rubber impeller or even a diaphram choke pump would work
 (I think) don't shoot me if I'm wrong I have some uses!
Tugger
Re: Float Switch
« Reply #9 on: March 25, 2007, 02:58:43 pm »
Have just bought and built a Maplin water detector and hooked it up to a small diaphragm pump from Model Motors Direct and it works perfectly even on 12v. The circuit is very simple two resistors and a Transistor so I am going to build my own version which should cost pennies to make. When I have got it to work I will post details for others to use.
RickF
Re: Float Switch
« Reply #10 on: March 25, 2007, 03:21:29 pm »
Coming in a bit late on this, but wouldn't a car fuel tank switch do the job?. I think they are thermistors (basically a transistor which reacts to temperature - hotter or colder when wet or dry).
 On my car it turns a light on when fuel is low, so you should be able to adapt the circuit to turn a pump on when water is high.
Rick
Doc
Re: Float Switch
« Reply #11 on: March 27, 2007, 05:23:06 am »
Tugger,
If you don't mind experimenting a bit, you might try this circuit.  It's very generic and simple.  Hardest part will be finding the corresponding 'UK'/'USA' parts (only 'touchy' one is the SCR).  The majority of the parts are 'dirt' common, nothing special at all except for the 'sensor', sort of.  It's usually made form an etched circuit board, but can be almost anything within reason.  The 'contacts' must be closely spaced, but NOT touching!  The switch(SW) is nice but unhooking the battery does the same thing.  Nothing is to 'scale' so the finished size of the  sensor is variable, whatever works.  Same for the board the other components are on, how ever you happen to assemble them is fine.
 - 'Doc
please excuse the drawing.
« Last Edit: March 27, 2007, 05:30:33 am by Doc »
Peterm
  • Inactive
Re: Float Switch
« Reply #12 on: March 27, 2007, 09:18:42 am »
Doc,   C106 SCR is readily available in UK.   Pete M.
For UK Mayhemers, one source is Maplins Electronics.
I`m not just old, I`m ancient
Captain Jack
Re: Float Switch
« Reply #13 on: October 11, 2007, 03:15:39 am »
Sorry, came upon this post a bit late, as I am new to the forum, but there is this awesome little item available in the US.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXDZ48
Umi_Ryuzuki
Re: Float Switch
« Reply #14 on: October 11, 2007, 04:43:43 am »
This is the circuit we use in our combat models... O0
http://www.queensown.org/technical-data-sheets-6.html
