Hi, i have recently bought a "Tornado 80" hydroplane as a ready to almost run. The shop where i purchased it sold me 2 7.4v overlander batteries 3600mah , a Robie outrunner motor & a 47mm X prop. I was told it would go 3 times the speed of my Pro boat Volere. Well it was a bit faster but not impressive, cavitate.d on every turn & listed to one side at full speed. I went back to the shop to be told i needed a bigger prop & the trims i thought would help were a waste of time. I fitted trims against the shops advise & cured the cavitating problem. Unhappy with the performance i took the boat to another more race like shop. After they had stopped laughing at the apparently unsuitable motor & hugh prop they recommended a 3600kv motor (a purple one) with a water jacket, a decent mount & 40mm X prop, speed controller was an Overlander 60A. Couldn't get this running as i use a pistol grip control & the thing wouldn't centre as it had no reverse. Now i like reverse. So i asked them to get me one. A"Fusion Hawk 60A" & a couple of 9.6v 5000 mah batts in series. That will do about 40 mph , 69000 rpm mate! even faster with two 11.1 li-pos.
So there you have my story. Thing is i took the boat to my local pond all excited like i was 14 (im 45) put in the 2 x 7.4s gave it a bit of a run. Mmm, not as fast as the Volere, cavitateing power dropped after 40 seconds of use, rested 20 seconds power returned for 5 seconds. Mmm, i'll change the batts. Now with 19.2v this should shift! Nope. Kept on cutting out & still not quik. Took the boat out the water, checked the batts, not even warm. So i gave it a little rev out of the water to see if the batts were ok, my uni-joint exploded, doh. Looked at the speed controller - Ooops. It had got so hot that the heat shrink had split open & i could hardly touch it, hence why it was cutting out.
Now after this long winded story my questions are this........
1. What should i put in this boat to make it quik? I only want to run electric.
2. What size prop should i use?
3. What speed controller will be best for use with twin 11.1v li-pos? & twin 9.6v?
4. How do i work out the Amp rating for the speed controller?
5. Has the shop miss sold me the parts or was it set up wrong?
6. KV of the motor X volts = r/p/m is this correct?
7. What is max r/p/m of a 60a speed controller?
I hope to hear from someone soon before i go back to the shop all unhappy. I'd appreciate some knowledge before hand.
Thanks for reading
Ralphy
