Author Topic: Rosegarth Tug  (Read 4631 times)
Bruce99
Rosegarth Tug
« on: October 25, 2011, 10:11:30 am »
 :police:
Because the inboard decks sides are so rough on my Mobile Marine Rosegarth tug, I am sticking 1 mm ABS card to them, that should enable me to complete the gunwhales. Any recommendations for the best adhesive for this job would be gratefully received.
Re: Rosegarth Tug
« Reply #1 on: October 25, 2011, 10:26:53 am »
Hi Bruce
For my inside edges I always use a filler paste  (P38).  This sticks to the fibre glass a treat and can be sanded smooth and flush.  No worries whether it will come unstuck.  You might need two coats if it's unduly rough.
Hope this helps
ken
Re: Rosegarth Tug
« Reply #2 on: October 25, 2011, 11:46:23 am »
Laurie (Model Slipway) once recommended scraping a GRP /Fibreglass hull gunwales with new 'Stanley' blade and sand to a finish.
Re: Rosegarth Tug
« Reply #3 on: October 25, 2011, 03:18:20 pm »
Bruce
Ring MMM
They are ever so helpful
They will give you advice
farrow
Re: Rosegarth Tug
« Reply #4 on: October 26, 2011, 09:07:56 am »
I followed Shipmate60's advice, smear P38 inside then rub it smooth with wet and dry, worked a treat for me.
justboatonic
Re: Rosegarth Tug
« Reply #5 on: December 16, 2011, 09:14:18 pm »
Hi Bruce
Hope this helps
ken
Yep, this is the way to go. I sand them inside so it is smooth-ish without unduely making them too thin. Then apply a very thin smear of car body filler and sand again. If it still isnt smooth, apply another thin smear and sand again.
Two points though. Dont add to much filler each time as you'll only end up sanding most of it off! Secondly, I dont make the surface baby bottom smooth and prefer a little uneveness in the finish as I personally think it makes for a more scalish appearance.
Page created in 0.036 seconds with 21 queries.
