Author Topic: How to wire a microswitch  (Read 13016 times)
More Coffee
Re: How to wire a microswitch
« Reply #25 on: November 16, 2011, 09:52:46 pm »
Quote from: Mad_Mike link=topic=33583.msg 331840#msg 331840 date=1320259476
if you were to use 2 micro switches in parallel wiring would this overcome limited current issues?
Just use the micro switch to power a relay ,use low current across the switch to fire a relay that will sustain the current ..If that's not possible ..just about any 12 or 24 volt surface mount starter solenoid will suffice..
Page created in 0.079 seconds with 19 queries.
