Author Topic: sails  (Read 2161 times)
regiment
sails
« on: November 03, 2011, 01:21:37 pm »
i am building a yacht how do you fix the sails to the mast and where do you buy the fittings from   thanks
dreadnought72
Re: sails
« Reply #1 on: November 03, 2011, 02:41:58 pm »
There are three main ways to fit a fore-and-aft sail to a mast:
A sleeve of sail slides over the mast (as used on the unstayed masts of Laser dinghies).
The sail runs up a track or groove in the aft face of the mast (as used on most dinghies with stays on their masts).
The sail contains hoops which run up the mast as the sail is raised.
I think we need more information about your yacht, regiment!
boatmadman
Re: sails
« Reply #2 on: November 03, 2011, 02:49:30 pm »
Or you can use rope through eyes in the sail and around the mast.
regiment
Re: sails
« Reply #3 on: November 03, 2011, 03:15:56 pm »
thanks got the idea
roycv
Re: sails
« Reply #4 on: November 03, 2011, 04:43:24 pm »
Hi, you can also use a 'jack line' This is a tensioned line at the back of the mast about 1/16th inch out and can be held in place with small split pins, mast drilled and glued to hold them in place.  You can use thin piano wire for this as well.
 Simple hooks from hook and eye use for the sails.  Or use 1/2 inch lengths of white plastic tube held to the edge of the sail with adhesive sail cloth.
I have used this system 2 or3 times and it works well.
Oldest one about 10 years old and no sign of wear.
regards Roy
rmaddock
Re: sails
« Reply #5 on: November 03, 2011, 06:58:34 pm »
Page created in 0.085 seconds with 21 queries.
