Mark
Being new to current modelling I don't even know what a BEC is
Could you please elighten me and advise how to proceed
The BEC is a device inside the ESC (in your case) that derives a regulated 5 volts from the main battery to power the ESC internals. In most cases, it also powers the receiver and anything else plugged into the receiver. Usually, they dont like to either charge a battery or be presented with a higher voltage than they are putting out, hence the advice to disconnect the red wire from the RX plug.
A lot depends on how the internals of the Mtronics ESC are arranged at this point, and they dont say. Usually, the internal stuff that processes the information coming from the RX is powered via the BEC, which is switched on by the small black switch. The red LED might not need this to function, so that if main power is there, but without anything else happening, it will light.
Best to try it like CF-FZG suggests, without the RX battery, but with the red wire reconnected. It will now be in the configuration that Mtronics expected when they designed it. If the servo works, there is power from the BEC. Assuming that the TX was switched on first, the ESC will have a signal to latch on to and you should have that few seconds to put it in setup mode.
This is ignoring the possibility that a TX reverse switch is thrown - this can create real confusion when trying to set up an ESC.
Next step would be to contact Mtronics, because if it is getting a valid signal and proper power and not responding, its broken.
