Hi Ian / Peter
for several reasons (partly ex IC) the standard mount wasn't meeting my needs so I have a custom one which is perfect
but for one slight adjustment that might be needed after it is first fixed. The tiny adjustment in the plane the mount lies in
was discussed when the mount was first made.
I could do as you suggest Ian and put some epoxy under there but -
the foot area of the mount isn't very big (for a reason) and more importantly the kind gent who made the mount said it
might only need a tiny little bend to get perfect. As I said above after reading the medical thread, our/my worsening
eyesight needs any help it can get; hence the thought above, but I am here to learn.
Re 'solid piece of bar drilled one end for the shaft and the other for the motor concentrically' yes I can see that is good if
you have the tools to drill a thin bar to suit - or if it could be purchased with M4 holes already.
