A little local skirmish on another thread led me to research Huco couplings and I found some stuff on Farnell's website here. http://www.farnell.com/datasheets/529891.pdf. HUCO's own website has much more detail but I'm afraid that me and Newton.Metres don't agree at this hour of the day.
The implication is that those HUCO-Pol couplings much beloved by us boat mogglers are only rated up to 1000RPM!
I leave the floor to the cognoscenti for further debate.................
Dave M
glad you should mention that, Dave
The reason I made the constructive comment was that I once had a Caldercraft PCF boat that I had built as a review model for (I think) Radio Control Boat Modeller and they were fitted with high revving big torquey motors (similar these days to the torpedo 850) and was fitted with the couplings that Martin mentions. The white ones with alloy couplings. I had left the end shafts connecting to the couplings protruding some two-3inches from the Tubes for access to the motors under the deck, as the rear deck was fully closed for access/water tightness.................I only did one sailing run with it.and in my younger inexperienced days way back in the early 1980's...........yes, you guessed it....one coulping shattered under the high ( think about 6 -7000rpm,) and as it shattered, the shaft bent with the inertia at that speed with half a coupling still attached to it adding weight,almost at right angles, taking some of the prop tube with it and punched a hole through the grp hull.....I had to go into the lake at Fleetwood fully clothed to retrieve a very quickly sinking boat.I still hadn't got full photo coverage for the magazine article.
The electrics ( twin robbe 200 speed controllers at the time) plus futaba receiver where kaput with the salt water ingress into the hull and I learned from my experience.
Huco are not made for high speed motor transmission and the start up torque that a lot of motors give, especially if they are put under other stresses also.
Glad you brought it up Dave, so that I could give my views in a calm and none biased manner.
neil.
