Author Topic: Washport Positions  (Read 1878 times)
chingdevil
Washport Positions
« on: March 23, 2007, 10:47:10 AM »
I hope you knowledgeable people out there can help me.
I am building a Mountfleet Sealight Puffer and want to fit the working washports. The problem I have is this the hull thickness at deck level is 2mm, the washports are 5mm thick. So which side of the hull does the excess go or should they be flush? In which case I have some filing to do. :( :(
The other Brian 8)
Tug
Re: Washport Positions
« Reply #1 on: March 23, 2007, 09:32:05 PM »
A partially educated guess, inside,   ???
anything on the outside might snag, and the doored sort would open to let the water out and not in.
But I will give way if wrong.  tug
Junk is something you've kept for years and throw away three
 weeks before you need it.
Bryan Young
« Reply #2 on: March 23, 2007, 10:31:40 PM »
The other Brian 8)
The top of the "flap" is inboard and the lower 2 thirds is outboard. Hinge 1 third of depth from the top. Therefore the port closes under its own weight when the ship rolls the other way.
Notes from a simple seaman
John W E
  • I see no ships !!
« Reply #3 on: March 24, 2007, 09:40:38 AM »
hi there Brian chingdevil
Washport doors are normally the same thickness as the side bullwarks so I am afraid you will have to thin down yours from 5mm to 2mm thick - or, you could actually, if you prefer, manufacture new ones out of 2mm thick plastic card.    If this doesnt help, give a shout - Ive got some drawings which I can dig out for you.
aye
john e
bluebird
chingdevil
« Reply #4 on: March 25, 2007, 06:56:05 PM »
Thanks for the tips guys. looks like I have some sanding to do, or if that fails make some new ones. Now where di I put the angle grinder. ;) ;)
The other Brian
