Author Topic: Omra Makara D Class  (Read 191151 times)
Bill D203
  • not long now!!
Re: Omra Makara D Class
« Reply #250 on: November 30, 2007, 05:18:07 pm »
Mines coming along.
Bill D203
  • not long now!!
« Reply #251 on: November 30, 2007, 05:20:24 pm »
Inside my boat.
2772e
  • Simon
  • The Sea Shall Not Have Them
« Reply #252 on: November 30, 2007, 05:41:08 pm »
Looking good Bill, have you run  her yet?
Have you got a bulkhead?
BW
Simon
Rubbin is Racin!
Bill D203
  • not long now!!
« Reply #253 on: November 30, 2007, 06:34:27 pm »
Hi Simon.
Yes it's going well . I have lots of small jobs to finish. Maybe i will get some done on Saturday, if Her indoors dose not want me to do the Christmas shopping.
I am trying not to put a bulk in as I may well fit a ballasts tank + pump in the front. I have got loads of foam float stuff to fit in. That should keep her from going under.
As and when she dose take to the water I will see if I can get a video of the event. {-) O0
pete_486
« Reply #254 on: December 02, 2007, 12:27:04 am »
hi bill it's looking nice hoping to see the maiden soon lol.
Pete
Bill D203
  • not long now!!
« Reply #255 on: December 02, 2007, 12:17:01 pm »
Well that day has come when weeks of work have been placed in that big lake. Pity about the rain but it did little to dampen my spirits. The engine was started after a little pulling on the starter rope, dumped in the water and off see went . Not bad I was thinking, When this woman who must have got out of bed the wrong side started to rant a rave about the smell, up setting the wildlife. In Stevenage i took it be all the local youth but they was all in bed. No she meant the Ducks!! Sill Blow it all I was having a lot of fun. A few things to short out, but things are looking real good for next years OMRA racing. Cheers for now Bill.
2772e
  • Simon
« Reply #256 on: December 02, 2007, 01:58:40 pm »
Bills Makara fisrt run.
Video link to Utube.
http://uk.youtube.com/watch?v=aob31iLFNV0
Well done Bill
Rubbin is Racin!
« Reply #257 on: December 02, 2007, 02:50:37 pm »
Ducks being disturbed, funny the one in the video deos not seem that bothered
pete_486
« Reply #258 on: December 02, 2007, 03:24:36 pm »
its running quite well for its first run.
on my first run i opened her up, and it lept out of the water on its prop and could not keep the front down and it took weeks to set up even Kurt was baffled by it.
on further inspection there were two large rockers near the transom, so i got the heat gun out and put trim tabs on.
now it will not turn left.
Pete
Bill D203
  • not long now!!
« Reply #259 on: December 02, 2007, 03:40:03 pm »
Hi Pete. Yes Very happy apart from a transmiter full of water. Still it's now drying out on my rad indoors.  ::) I will have to reset it all agian. Oh well all the fun of boating in the rain 8)
AC RAZOR 45
« Reply #260 on: December 02, 2007, 10:06:16 pm »
Hi Bil yes good maiden run,mine to like Pete's had rockers in the hull but removed them in the build now with adjusted trim tabs runs well at turns well both ways,i look forword to seeing you at the odd race next year...al O0
2772e
  • Simon
« Reply #261 on: December 03, 2007, 06:30:29 pm »
AL
Talk to me about these rockers?
Simon
Rubbin is Racin!
omra85
« Reply #262 on: December 03, 2007, 08:41:12 pm »
Simon
"Rockers" are big hairy bikers from the 60's.  If they had a couple on the back of the boat - it's no wonder it didn't go  {-) {-)
Hope they removed them politely!
Danny  :D
2772e
  • Simon
« Reply #263 on: December 03, 2007, 08:51:46 pm »
Thanks Danny, can allways rely on you top look at things from a totally different angle!
Hows that Magnum coming along. Want me to fit it out for you, and add the paint?
BW
Simon
Rubbin is Racin!
Bill D203
  • not long now!!
« Reply #264 on: December 03, 2007, 09:04:39 pm »
Hi Simon
I was in the RED Bull F1 place today, showed them your pic's of your boat and video. There paint sprayers seemed to like what they saw.
Bill O0
glennb2006
« Reply #265 on: December 04, 2007, 04:24:37 am »
Pete
Hmm,
I had until very recently a Panther that would not turn left. I mean, full left rudder and nothing happened at all. As soon as you shut the throttle it would turn, but not until then.
I cured it eventually, at least it seems like I have. If I get some flat water in the next week or so I will try it flat out and see what happens, but so far 100% better.
Those Makara's seem to go well.
Glenn
2772e
  • Simon
« Reply #266 on: December 04, 2007, 07:30:45 am »
Glenn,
I had a similar problem racing at Bristol this year. It turned out to be the servo, i changed it and it was fixed?
Rubbin is Racin!
glennb2006
« Reply #267 on: December 04, 2007, 12:51:16 pm »
Mine was a trimming issue. Took half an hour to sort, just needed the drive moved over. And a rudder adjustment.
Glenn
pete_486
« Reply #268 on: December 04, 2007, 10:52:02 pm »
ive just put a hitec hs-805bb 25kg of torque at 6v on the rudder and that was the last run and still no left.
hence the bent sign  :embarrassed:
Pete
martno1fan
« Reply #269 on: December 04, 2007, 11:05:38 pm »
Maybe you got your rudder too far over to the right ? also try a longer rudder could also be prop walk ? is the prop sharp i know the last ones probably a no brainer but  if its none of those things then your hull has a serious hook in it somewhere ?.As it seems more than one has this fault maybe you need to send it back to nimriff? .My mates cat was a complete disgrace from them and it went back for a refund (after solicitors got involved).Werent you singing the praises of this boat a week or so ago yet it wont turn left i find that strange,so its not quite as good as you reckoned then?.
martno1fan
« Reply #270 on: December 05, 2007, 12:00:11 am »
What prop are you running? sounds like it could be a lifting prop which could be making it bow steer?.Also have you painted the hulls bottom? this can also alter things for the worse,also check your strut is dead stright with the keel line maybe its twisted slightly to the right ?.MY MONEY IS THAT BIG PROP TRY A SMALLER ONE AND ILL WAGER THE LEFT TURNS COME BACK  ;).
martno1fan
« Reply #271 on: December 05, 2007, 10:14:21 am »
Read this,lifting props if its octura has no letter on it you need one with a v or an x on it for a non lifting prop.Anyway read this lot and maybe you will find your problem.maybe your rudder is too short? mine was on my woody so i made a longer one?.
http://www.modelpowerboat.com/RC_Boat_Hull_Attitude
Blagmeister
« Reply #272 on: December 06, 2007, 04:55:26 pm »
Well finally my Makara hull has arrived together with some of its bits and pieces, albeit I am going to have to hang fire on a lot of the work until I get the engine mounts which could be another week or two.  [I don't want to start mucking about with the tube until I have got the engine in. Dunno if this is right but it strikes me that I need to get things lined up reasonably well, first time].
I had a good look at the hull and it seems to be ok [with the exception of a couple of gelcoat flaws in the topsides which a bit of judicious gelcoat filler should sort out.  The hull itself seems to be free from any flaws going by eye but until I get a decent straight-edge on it, I won't be sure.
This is going to be my first build so Simon, stand by to be bombarded with seemingly stupid questions!
I'll do a full pictorial on it as the build progresses, [if that sort of thing goes down well here?]
Phil
Bill D203
  • not long now!!
« Reply #273 on: December 06, 2007, 05:14:33 pm »
Hi Pill
Good to here your boat has come in at last. Re engine mounts. Are you fitting stringers? I did on mine using 9mm ply.  It adds a little weight bur it all so strengthens up the hull. Re the gel coat. Snap. It would be interesting to know where yours are to compair the two boats. Who's running gear are you using? I used the gear that Paul suppled which seem's to be OK on it's first outting last week.
If I can be any help just sing out.
Bill Warder. O0 :-\
Blagmeister
« Reply #274 on: December 06, 2007, 05:49:05 pm »
Hi Bill
I hadn't planned on fitting stringers. I was going down the route of glassing in the mount bases to the hull. Paul at Nimrif suggested this method was much more preferable to using ply stringers and on the basis that he has far more experience than me, I thought I'd take his advice!
Having said that, I'll give this method a go and if it doesn't perform as well as hoped then I may well look at a future build using stringers but perhaps made from a composite material. [No possibility whatsoever then of the stringers becoming soft through water ingress].
As for the gelcoat flaws, I have a few creases on the topdeck, port side.  Nothing too serious and a bit of P40 should sort it. When it's been painted and lacquered, I don't think they will show at all.
Pages: 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26   Go Up
