Model Boat Mayhem - Forum
Author Topic: Advice needed for Accucel 6 charger  (Read 1154 times)
Paul R
« on: November 24, 2011, 04:13:21 PM »
Hi..
Not had this very long, using it for 3S li-po batts. I notice there is a program for li-po charge and li-po ballance charge.  On li-po charge, battery seems to charge and the cells seem to be monitered as you can check this via the display. The same seems to happen with the li-po ballance charge program, so whats the difference ? Is the ballance charge just to ballance the cells or does it charge the batt at the same time as well? Which program should I be using.  ????
Thanks.
Re: Advice needed for Accucel 6 charger
« Reply #1 on: November 24, 2011, 04:21:05 PM »
Instructions here  on youtube
http://www.youtube.com/watch?v=BYFHQHQ1aD8
MANUAL here
http://turnigy.co.uk/downloads/accucell-6_manual.pdf  Suggest you print it off.
Paul R
« Reply #2 on: November 24, 2011, 04:37:18 PM »
Yeh. Got the manual, its not much help.....
If anyone has used one of these chargers perhaps they could advise which program to use for li-po charging..
Many thanks
« Reply #3 on: November 24, 2011, 04:43:03 PM »
Try the youtube one, it says you need to balance charge when the battery has more than one cell.
barriew
« Reply #4 on: November 24, 2011, 05:35:54 PM »
You need to balance charge your lipos - not sure why you would want to charge lipos without balancing them. And yes it does charge as well :-))
Good to have you back on duty Richard :-)
Barrie
« Reply #5 on: November 24, 2011, 05:48:49 PM »
Thanks Barrie
Tombsy
« Reply #6 on: November 24, 2011, 05:54:50 PM »
I balance every charge but I've read it's not always necessary on every charge maybe every 2 or 3 charges, I'm guessing it's faster to charge without balancing. You can get one of those $5 digital testers to see if the cells are in line.
