Hi folks one of the hardest things I have come across so far is trying to get the the deck level right is it best to put the support timber in in short sections or try an get it in a longer length any tips on this ?
When I did the deck on mine, I used the clearing ports, or wash ports some people call them as a guide. I glued an off cut of the deck to a small flat piece of ply. I laid this in the bottom of the clearing ports with the glued deck size piece just inside, and lined the beam shelf up with that, when the deck was laid on the beam shelf it was level with the bottom of the clearing ports.
i have been building mine for two years now, I have the hull and accomadation block painted, wheelhouse windows fitted, and have tested her on the lake. very happy so far. Have not had much time to build due to chnges of job etc, and working away from home.
