Hi, Ian
To try and answer your question
What's the best recovery plan? Obviously I can sand off the bumps but what about the holes and tissue patches? If I put another layer on will it smooth out the depressions or will I just end up with the same situation under a thicker layer! Or should I give up, sand it back to wood and try again a little wiser?
Yup, sand it clean and sanitary again, and do it again
with a smaller mix. I think Anteo is a big mother - and I Know that you mixed up a fairly large bulk in a deep container, like a cup. Am I right?
ZAP is a very reputable brand, and will behave beautifully next time
Before mixing (and before your hands are goopy and sticky) cut out all the glass, and lay it out in order of use - you can (if you wish) give the hull a LIGHT spray of spraymount to hold the glass in place
Mix in a shallow container (I use a shallow polythene bowl made for this - from the Fibreglass Shop)
You cannot mix too well
Most epoxies at room temperature will give you about 30 to 60 minutes of working time. If you get less then you probably have been sold the winter catalysy (unlikely) or the temperature has "run away" more likely
hope this helps
andrew
