Author Topic: connectors  (Read 2156 times)
daveorgan
connectors
« on: December 08, 2011, 05:21:27 PM »
can anyone recommend any good connectors  rated for 20 - 30 amps
regards
Re: connectors
« Reply #1 on: December 08, 2011, 05:28:07 PM »
Craplins do what you need or
Car part emporiums for spade or bullet
tt1
Re: connectors
« Reply #2 on: December 08, 2011, 05:37:05 PM »
Dean's ultra connectors are widely accepted as excellent and can take at least 100amps so they state.
daveorgan
Re: connectors
« Reply #3 on: December 08, 2011, 08:26:48 PM »
found them on ebay thanks alot  :-))
nemesis
Re: connectors
« Reply #4 on: December 08, 2011, 09:41:13 PM »
Ill second that, I have gone onto Deans, very good & so positive, A tip, keep them connected when soldering them. Nemesis
RaaArtyGunner
Re: connectors
« Reply #5 on: December 08, 2011, 09:59:58 PM »
Do they distort with heat?
Re: connectors
« Reply #6 on: December 08, 2011, 10:10:57 PM »
The insulation can melt if allowed to get too hot.
It is better to use a hot soldering iron quickly.
Pirate
Re: connectors
« Reply #7 on: December 08, 2011, 10:31:24 PM »
Google 'XT60' connectors! We have purchased them via e bay and they do NOT melt. Most excellent.
Pirate
daveorgan
Re: connectors
« Reply #8 on: December 08, 2011, 10:52:34 PM »
Pirate
found them on ebay mate 5 pairs 3.99 free postage cheers :-))
gwa84
Re: connectors
« Reply #9 on: December 08, 2011, 11:02:04 PM »
have to second the xt60 conectors just a not ive found that tou should always solder them with a heat shunt on the other side of the conectior stops them from sofening the nylon and the bullets moving out of alignment
CF-FZG
Re: connectors
« Reply #10 on: December 08, 2011, 11:08:16 PM »
Much safer to use a heat shunt on Deans too :-)) - they can ,and do, go out of alignment by using the other half of the connector ;D
Mark.
barriew
Re: connectors
« Reply #11 on: December 09, 2011, 07:44:33 AM »
Try the ones from Giant Cod - they dont melt AND they have ridges moulded in so they are easier to grip.
Barrie
