Today, I was informed of a few items for the aft cabin of the "Smuts" by my guru..........a steel box for holding the line throwing equipement, a box for holding the lines/rockets etc, and an open pigeon hole type locker for holding flairs.
The latter was to be split into 16 pigeon holes.......I had a locker that I had made earlier that I thought would do for the rockets and lines to go under the starboard bench, aft cockpit, and the steel box will be made from a block of obeche, but the pigeon hole locker, I had to scratch from plasticard, using a "carcasse" of 1.0mm plasticard, with an inner set of interlocking 0.8mm card to make the pigeon holes.
Secondly was the making of the mizzen masts from 6.0mm dowel and resin cast brackets and base plates to hold both masts in place at their set angles.
