Author Topic: Bowthruster for 1/16 severn  (Read 4606 times)
returnee
« on: December 15, 2011, 04:18:45 pm »
Can anyone suggest the correct size tube (external dia.) of a working bow thruster to fit in a speedline 1/16 severn. the tube supplied @22mm seems small, your thoughts please.
Gerard
stuarts2
Re: Bowthruster for 1/16 severn
« Reply #1 on: December 15, 2011, 06:10:34 pm »
Hi the tube that come with my kit was at 22mm and was correct, got my thruster from Deans Marine works fine, how you getting on with the build?
returnee
« Reply #2 on: December 17, 2011, 03:07:49 pm »
Hi Stuart,
Not started yet, just trying to get all the bits and pieces together before starting.
Will go with the 22mm.
Gerard
Mungeltuete
« Reply #3 on: December 30, 2011, 07:16:10 pm »
Hi Gerard,
I have installed a 22mm brass bow thruster --> http://www.hobby-lobby-modellbau.com/onlineshop/product_info.php/info/p3912_Bow-Thruster-20-mm---Brass-Tube---1-Prop----5101-11.html
Here also some pictures of the installed bow thruster:
I hope that helps.
Cheers,
Markus
returnee
« Reply #4 on: December 30, 2011, 07:22:25 pm »
Hi Markus,
Thanks for the info, it looks a very substantial unit, and pricey.
It certainly looks the bees knees.
Gerard
nhp651
« Reply #5 on: December 30, 2011, 08:23:57 pm »
Hi Markus......lovely looking product ......what voltage does the bow thruster work off. thanks.
neil.
« Reply #6 on: December 30, 2011, 09:57:50 pm »
Hullo Markus.......the sectional image of the 5101-11 bow thruster does not show, but are the two 20 diameter tubes sealed to the central drive hub with an o-ring on each side? .........Derek
Mungeltuete
« Reply #7 on: December 31, 2011, 10:21:18 am »
Hello Folks,
@Neil:
The bow thruster comes without motor. So the voltage depends on the motor you connect. The bow thruster has a 3mm shaft and you can connect any motor you want.
@Derek:
There is no o-ring between the tubes. Better you use some sealing paste or solder the pieces together.
Cheers,
Markus
nhp651
« Reply #8 on: January 01, 2012, 12:42:19 am »
thanks Markus..that makes it even better of a purchase.
thanks.
neil.
