Pages: 1 2 3 [4]   Go Down
Author Topic: HMS Macedonian  (Read 57070 times)
JimG
Re: HMS Macedonian
« Reply #75 on: March 30, 2020, 11:06:17 am »
Have you tried printing the problem items with supports which will raise the object off of the bed. Also does your printer have a pause option during printing. My Anycubic Photon S has this and it raised the bed out of the resin allowing for a quick check that the print is going OK. I usually use it after around 200 layers to check that the print is sticking to the bed.
Jim
Dundee Model Boat club
JerryTodd
  • Scale Sailor
    • Modeling Projects
Re: HMS Macedonian
« Reply #76 on: March 31, 2020, 04:08:44 am »
I did put them on supports, but I intent to try putting them a little higher off the plate with heavier supports - I used "medium."
I'll have to look into that pause idea, I thought about it but was afraid to accidentally cause the print to cancel.
I do need to slick the film at the bottom of the vat so things don't stick so hard, I've lost two prints and one carronade slide that were actually pulled off thier supports.
JimG
Re: HMS Macedonian
« Reply #77 on: March 31, 2020, 11:57:10 am »
I wouldn't worry about accidentally cancelling using pause, I have found it 100% reliable in restarting print. Not that much you can do about the surface of the film, be carefull as it is easily damaged. Just keep a few spare films handy for replacment especially if the film surface gets scratched or start going cloudy with fine scratches if you have to remove a failed print from the film. Repacing the film is quite easy although time consuming, just make sure the tension on the film is right.
Jim
JerryTodd
  • Scale Sailor
    • Modeling Projects
Re: HMS Macedonian
« Reply #78 on: June 19, 2022, 08:48:01 am »
Not much happening with Mac for a while.
I started on a 3D model for her 18 pounders with the intention of printing gun and carriage all in one piece like I did Constellation's pivot guns.  It wasn't a complete model, but it printed great and now lives on my bookshelves.
The first things I had in mind when getting a 3D printer was Constellation's tailboard carvings, and Mac's figurehead.  So far when it comes to 3D modeling these items, I suck.  Furthermore, every time I look at what's alleged to be Mac's original figurehead, I have my doubts.  The thing looks like a caricature and I think the figurehead was damaged when the ship was bow raked, and repaired by the United States' carpenter with his tongue planted in his cheek.  I think the figurehead was a much nicer piece of work than whats sitting in Annapolis today, and so I scaled a 3D model of a bust of Alexander and did a test print of it as the model's figurehead.
dlancast
Re: HMS Macedonian
« Reply #79 on: June 19, 2022, 02:43:05 pm »
Jerry, outstanding!  3D and photo-etch have boosted modeling making in amazing ways.  Tks for sharing, always enjoy your work sir.
Cheers, Dennis
JerryTodd
  • Scale Sailor
    • Modeling Projects
A Galley Stove
« Reply #80 on: November 14, 2023, 11:13:35 pm »
I began modeling a Brodie stove for Macedonian for 3D printing.The Brodie stove was the most common type on British warships till 1810, when the Lamb & Nicholson stove began taking over.Macedonian was launched in 1810, but I'm assuming the stove was requisitioned some time before, and was most likely a Brodie.
The 3D model was done in Anim8or, and a test print was made on my Elegoo Mars 3 printer.  Some items were too fine to print properly, or visibly, so I went back to the model and beefed up the details.
Hopefully the next print won't need any adjustment, though the upper chimney part may need to be stretched a bit to be tall enough, and reprinted.
JerryTodd
  • Scale Sailor
    • Modeling Projects
Re: HMS Macedonian
« Reply #81 on: November 17, 2023, 03:36:16 am »
Looking in Lavery's Arming and Fitting of English Ships of War I found a chart on page 198 (2006 edition) showing various stoves sizes for ships of different gun ratings.I adjusted the model to the sizes listed for a 38 gun ship, and printed it again.
Re: HMS Macedonian
« Reply #82 on: November 17, 2023, 03:09:55 pm »
What an interesting project! It reminds me of Warspite's build of a few years back. I noted your clever use of a modified Craft Knife (Stanley) blade, turning it into a profile scraper! (post #55)
I noted that your topic started in 2011 Jerry. I think that must hold the record for being the longest active topic on Mayhem?
Lovely work matey  :-))
Re: HMS Macedonian
« Reply #83 on: November 17, 2023, 05:59:25 pm »
Unique special model Galley Cooks Jerry ....two beating their sweating brow  O0 .................
Family friends of ours purchased an old home complete with one of those huge two-tone 'creme & green enamelled coal-fired kitchen stoves'
Was the warmest part of the home...we all gathered around it as they are great heaters
JerryTodd
  • Scale Sailor
    • Modeling Projects
Taking my Time by the Stove
« Reply #84 on: November 18, 2023, 03:08:54 am »
I started Macedonian in October of 2011, but I started Constellation in February of 1999.  We moved and Constellation sat under a plastic sheet in the barn until 2008 by which time, I had moved a couple of times more before finally starting work on her again.Pride of Baltimore was started in November of 2010, and sat until September 2011, when I started planking the hull.
Macedonian, I'm sorry to say, tends to be at the lowest priority in my sketchy work schedule on these three models.  Besides them, I have a barkentine I haven't really started yet; a 100 year old pond yacht to restore, and a plastic kit of a WWII destroyer to do.  I had a Heller 1:100 Victory for a while, a kit I had dreamed of having when I was a teen, but I sent that one off with a young man to give his father.
The first boat I crewed on was a Chesapeake Bay Skipjack (sailing oyster dredging boat) built in 1905 named Minnie V (that's Vee, not 5)  She had a cast-iron two-eyed potbelly stove in the cabin that did a nice job heating our little home, as well as some canned goods now and then.
Several boats I've worked on had stoves that were characters unto themselves, but the stove that's always stuck in my memory was from my reenacting days doing American Civil War Union Cavalry.
One drenching rainy day at Piedmont Station Virginia, we rode up to the general store in town that had a covered porch, big double doors, and a 6 foot tall pot-belly stove in the middle of the place with chairs all around it.  It was a great place for a platoon of soggy Yankee (we were a Maine regiment) cavalry to warm up.  Ahh, sitting in a rocking chair, smoking a cigar, and drinking coffee from a tin cup.
Oh, the other brow-beater's actually toting a powder keg ;)
JerryTodd
  • Scale Sailor
    • Modeling Projects
Re: HMS Macedonian
« Reply #85 on: January 31, 2024, 08:59:09 pm »
With Constellation's boats done, except for finish paint work, and it still too cold in my shop to do that, I'm coming back to Macedonian and and ambitious project to to the entire stern and quarter galleries in 3D.
The pics are work-in-progress.  I actually printed the version in the first picture, but the scale was off (too small) and I had to figure out why; I think I have that fixed now.
JerryTodd
  • Scale Sailor
    • Modeling Projects
Re: HMS Macedonian
« Reply #86 on: January 09, 2025, 11:29:33 pm »
Till last spring I was working at getting Pride of Baltimore sail-able when I went and had a stroke.  It's been a few months, trying to get some dexterity back, not that I had any to begin with, when winter showed up and the shop became too cold to be in.
So, it's back to 3D modeling (where it's warm), and maybe some crew figure painting?  I've been trying to wrap my head around Blender  to get to where I could model the ornate carvings found on Constellation's head and Macedonian's stern.  That's not going so well, so I fell back to Anim8or, which I know, and something I'm fairly proficient at, cannons.
I started some basic models of Macedonian's guns a while back, so it was more about adding details, except I started over from scratch on the carronade slide.The carriages are based on several scale drawings, photos of HMS Unicorn's 18 ponders, and HMS Trincomoleee's carronades.
The STL files for both guns are on my Thingiverse page
SailorGreg
Re: HMS Macedonian
« Reply #87 on: January 10, 2025, 05:31:01 pm »
Sorry to hear of your stroke Jerry, but glad you are on the road to recovery.  Nice work on the gun modelling.  I hope you can get your fleet afloat soon, armed to the teeth!
Greg
JerryTodd
  • Scale Sailor
    • Modeling Projects
Re: HMS Macedonian
« Reply #88 on: January 12, 2025, 04:12:12 am »
I appreciate that Greg, thank you.
So I test printed each of the guns, and will beginning full production as soon as the new bottle of resin shows up.
JerryTodd
  • Scale Sailor
    • Modeling Projects
Re: HMS Macedonian
« Reply #89 on: January 16, 2025, 06:14:48 am »
It's still to cold to work in the shop, been below 0°c around here for a week or two, so.... I started on a 3D model capstan.I based my model on a drawing from the NMM of HMS Neptune's capstan as taken off at Deptford Yard in 1796I made the model to be printed in two part, the spar-deck capstan, and the gun-deck capstan.  The main post, or pillar was split between upper and lower.  I wasn't going to print it until I had decks going into the model so I could adjust the upper portion to fit the space between decks, but something told me to do a test print anyway, and good thing I did - 'cause it failed!As the pictures show, the portion on both capstans, where the sockets for the capstan bars go almost didn't print for some reason, but the disks above and below did!So' I reworked the 3D model to hopefully fix what I think caused the failure.  I'll see in four hours or so if I fixed it or not.  ;)
JerryTodd
  • Scale Sailor
    • Modeling Projects
Re: HMS Macedonian
« Reply #90 on: January 17, 2025, 11:08:49 pm »
After fixing the 3D model and printing again, I got a usable print.I haven't figured out why, but it printed over the hole in the bottom again, but I'll live with that.
The STL's been posted on Thingiverse for anyone to take a shot at who wants to.  ;)
JerryTodd
  • Scale Sailor
    • Modeling Projects
Re: HMS Macedonian
« Reply #91 on: January 25, 2025, 01:36:02 am »
It took a while, but I got all Mac's guns and carronades print, plus a few extras.I also made her wheel, based on the model for Constellation's wheel, I already had.
JerryTodd
  • Scale Sailor
    • Modeling Projects
Re: HMS Macedonian 1812
« Reply #92 on: January 28, 2025, 01:02:58 am »
I looked for data regarding gunport lids all over the net and in my books, with no real luck.  Everything is Victory and I couldn't even find good images of Trincomalee or Unicorn as references for a frigate's gunport lids.  I did find a drawing at NMM, basically a memo for gunports dated 1811.  Macedonian was launched in 1810, so I don't know how appropriate would be to my model, but I doubt it's too far off.  So I cobbled a 3D model of one together, and printed a few just to see.  I probably need to make some adjustments before printing a full set, but I think they7 do the job.  They don't need German optics kind of tolerances since I plan to have the guns run-out and all the lids open.The two gunports most forward are "catting-ports" and get split lids because a lifting lid would be in the way of fishing up the anchor, etc.  Haven't made those yet...I also stumbled over a lion face door-knocker STL file and though I could use it for the cat-heads.  I tossed some of it's "embellishments," like the knocker, flattened it, a lot, and put a square block behind it.  In my scale it's 1cm square, about the size of someone's pinky finger-nail.The other item I made are dead-eyes.  There's 6 different sized ones just for the lower shrouds and stays, and I'll have to guess at the top-mast shroud sizes.  I printed a few of the largest ones, I'll save the rest till I need them.
JimG
Re: HMS Macedonian
« Reply #93 on: January 28, 2025, 12:32:06 pm »
You won't find any photos of HMS Unicorn with gun port lids as she was never fitted with any. As she went straight to a starage hulk after launch the ports were all fitted with windows. Where these have been removed to allow for the replica cannons to be fitted the port lids were never fitted just a perspex window with a hole for the barrel replacing them.
In the case of HMS Trincommalee at least up to 2003 when I last visited none of  the open gunports were fitted with a lid. One port in the extreme bow and the two ports at the captains cabin were fitted with closed lids. I'll look out what photos I can find of these and post them here.
Jim
JimG
Re: HMS Macedonian
« Reply #94 on: January 28, 2025, 04:25:42 pm »
Here's some photos I have found for HMS Trincommalee, including the inernal rigging for the port lid. I have added a photo from HMS Warrior, much newer and metal lid but show the rigging. I have aqlso added some photos taken of 3 pages in my facsimile copy of Nares Seamanship 1862 showing the split lids at the bow.
Jim
Pages: 1 2 3 [4]   Go Up
