Having just moved into LiPos and b**gered one leaving the transmitter switched on tooooooooooooooo long, I decided that I should look after my new drive battery. I bought one of those gizmos with LEDs to tell you when the voltage is low.
The problem was how to use it.
So I've built it into the dashboard of the boat, so the driver can keep an eye on it. The green LEDs change to red when the voltage is low. They are a bit small to see but if you do a quick drive past it's possible to check, The red lights being a bit brighter than the green.
You can see imediately the voltage is a bit dodgey as they start changing to red under full power.
