Author Topic: Power leads?  (Read 6759 times)
Re: Power leads?
« Reply #25 on: December 31, 2011, 11:53:05 am »
ACTion
Re: Power leads?
« Reply #26 on: December 31, 2011, 12:16:36 pm »
Flux? We don't use it for production as we are only permitted to use lead-free solders. If you MUST use flux then be sure to wash it all off thoroughly after the joint has cooled; use soapy water for acid-based flux and standard thinners for resin-based flux, applying with a stiff brush like an old toothbrush and working the solvent right into all the corners near the soldered joint. If you don't then the stuff will carry on slowly corroding the surface of the metal and eventually the joint will fail.
Both of my soldering stations are analogue temperature controlled. I use a old Union Brothers type from Maplins, fitted with a 3.5mm chisel tip for larger joints and tinning stranded cables.The other is a Weller which cost nearly £200 with the iron, but it is like a magic wand for smaller joints with a 1.2mm pointed tip.
It's the best maxim in the world that there's nothing which beats the right tool for the job. As for soldering guns, I wouldn't have one in the workshop. I found them clumsy and unwieldy to use, with a heat setting which can damage anything delicate in no time flat if you're not very careful.
Soldering electronics is easy if you remember a few basic rules:
Hold the workpiece steady while you solder. I find a good old bulldog clip is as useful as any fancy multi-clamp (which I have also tried and discarded). Wooden clothes pegs are useful for holding smaller components where you don't want the heat conducted away e.g. those Tamiya metal sockets and plugs. For repeat work we use jigs made from scrap MDF, ply and pasticard.
Make sure you have a good level of light and that you can see the joint clearly. If you need reading specs then wear them. I have a pair of 2.5x magnifying lenses which clip onto my standard specs and flip up and down as required - perfect!
Keep the tip of the iron clean at all times. A quick wipe of the tip across a damp sponge as you put the iron back into the stand, and again when you lift it out to use, should become automatic.
Use the right size tip. A pointed tip for tinning thick cable or soldering large components is a waste of time; you'll never get the joint hot enough. You should buy an iron with interchangeable tips to allow you to select the correct size for the job.
Use the right temperature for the solder used - this should be shown on the reel. Typically leaded solder will be around 270 degrees while lead-free is much higher (370).
Never carry solder to the joint on the iron tip. Tin the tip and use it to apply the heat to the joint, then tin the joint before bringing the components together.
Allow the joint to cool before you move it. This avoids dry joints.
On PCBs, clean off any surplus flux around the soldered joints with either isopropyl alcohol or meths; for lead-free stuff we have to use a proprietary brand of cleaner called Total Clean 200, but it's over a tenner a can!
Sorry if this sounds a bit like "my way or the highway" but I've done a fair bit of soldering over the last five years and this advice - for what it's worth - is born of that experience.
Like someone once said, suit yourselves.
Dave M
Re: Power leads?
« Reply #27 on: December 31, 2011, 01:27:21 pm »
Just to add to DMs advice - cleanliness is almost everything.  The items to be soldered must be clinically clean and the metal must be bright.  Any dirt will spoil the join, any surface corrosion will prevent the join happening.
Most modern soldering tips are plated.  In the elder days, they were copper, and needed regular dressing with a file, then re-tinning.  This must never happen with a plated bit - a quick wipe on the damp sponge does the job of gently removing unwanted residues and ensures that the bit will have a long life.  Removing the residues by filing or sandpapering will damage the plating and cause the tip to corrode and destroy itself very quickly.
Patrick Henry
Re: Power leads?
« Reply #28 on: January 05, 2012, 09:18:08 am »
Thanks for the excellent advice gents, and also to DM @ ACTion for the 'how to' guide. Soldering has never been one of my strong points....yes, I know a lot of you chaps find it easy, but it's one of those things that I've always struggled with. I either end up with a joint half an inch thick, and then have to spend ages filing the excess solder off the joint, or making a perfect looking joint that falls to pieces in seconds.
I discovered a while back that we have a model engineering society in the village where I live, so my next task is to go along to one of their meetings (held in the local village hall just a hundred yards from where I live) join myself up and get some 'hands on' advice.
Thanks again to all of you who contributed to my post, much appreciated.
Re: Power leads?
« Reply #29 on: January 05, 2012, 09:35:51 am »
There's a world of difference between structural soldering, plumbing, and light electrical component soldering.  Many of the engineering society members will have good expertise at silver soldering and brazing big lumps of brass together, but might well be as lost as I am in that field when presented with some wires to fasten together.  The big similarity is that they all need the right tools and materials for the job.
Subculture
    • Dive-in to Model submarines
Re: Power leads?
« Reply #30 on: January 05, 2012, 06:58:54 pm »
I have four soldering irons I regularly use.
15w and 25w Antex irons. The Maplin 'el cheapo' temprature controlled 50w job linked to earlier and a big old iron with an unknown rating; it's an oldie as it has a bakelite handle and is akin to soldering with a poker!
The one that gets the most use is the Antex 25W. It's man enough to solder pretty thick cables, and handles well. The Maplin iron is exceptional value for money, I got mine for a tenner when they were on special offer a couple of years ago. I find the iron itself is rather more cumbersome than the petite Antex though.
The 15W Antex iron is reserved for very small jobs and soldering up PCB's, doesn't get anywhere near the use of the 25W version.
Re: Power leads?
« Reply #31 on: January 05, 2012, 07:32:15 pm »
Rich,
Most things are easy when you know how to and have a bit of practice.
You just have to know how and get in some practice!!
Re: Power leads?
« Reply #32 on: March 01, 2012, 01:28:42 pm »
Soldering technique demonstrated by my son aged about 6 at the time lol
Page created in 0.118 seconds with 21 queries.
