Author Topic: Springer Tugs  (Read 1621093 times)
Arrow5
Re: Springer Tugs
« Reply #1225 on: October 06, 2008, 02:44:28 pm »
Sprig ! yes I love it O0  Now who is going to build the biggest ?
..well can you land on this?
Guy Bagley
Re: Springer Tugs
« Reply #1226 on: October 09, 2008, 04:28:28 pm »
was thinking about a LEGO springer  :D...... may well have to be a 'maxi' springer though....
i have a concern if i built it conventional size in LEGO  my waterline may be no where near.....so may increase the dimensions slightly thus making the hull void larger, and hopefully giving me abit more free board....
 just a thought for a winter project !!!..... if i did make it in LEGO it wouldn't half leave a trail of destruction ( and parallel scratches) in a springer footy game !
andyn
Re: Springer Tugs
« Reply #1227 on: October 09, 2008, 04:55:20 pm »
You would need to cover every single last brick in epoxy, as lego leaks like a ******
And how appropriate was your signature was to that post.... coincidence???
Re: Springer Tugs
« Reply #1228 on: October 09, 2008, 05:07:12 pm »
We'll let you build one nearest to a convenient brick size Guy!  :-))
portside II
  • tugs at rest
Re: Springer Tugs
« Reply #1229 on: October 09, 2008, 05:33:25 pm »
I am sure i read on here that lego was imperviable to most glues , so what about making a lego plug and then casting resin and glass fibre to make a hull ,once cured you just break the mold .
daz
Guy Bagley
Re: Springer Tugs
« Reply #1230 on: October 10, 2008, 11:50:24 am »
dont worry i have proved LEGO  boats can float and not leak too badly.... the springer hull with its  sheer hull sides will be a walk in the park compared to my last creations !!!
the 'tag line' on my posts is no coincidence......
Guy Bagley
Re: Springer Tugs
« Reply #1231 on: October 10, 2008, 11:54:37 am »
daz
lego will glue happily with  plasweld and the likes, also most resins both epoxy and polyester will bond to lego... infact sometimes far too well ( if you know what i mean !!!! ) so depending on what you are trying to acheive then there is a material to do the job...
 building in actual bricks is fun,  and the GRP springer hull has been done before.... i like trying new things !!!- its half the fun and i like the challenge....
 just trying to plan why type of springer to actually make ?  a ;ego technic springer ?- a space lego springer ? or a huge gigantic LEGO DUPLO springer ( with the hydrodynamics of a sub post office ? ) ?
Bee
Re: Springer Tugs
« Reply #1232 on: October 10, 2008, 07:26:58 pm »
Surely the whole point of lego would be that once you have the hull the top can change every week. I quite like the idea....where's my nephew's lego got to.
Mr Andy
Re: Springer Tugs
« Reply #1233 on: October 18, 2008, 07:39:20 pm »
Right then the Springer MK1 was stripped down to nothing repainted fitted with one of everything and stuck back in the water, from looking at her you wouldn't know the difference. :-)
Andy :-))
toesupwa
  • USA'd ex Brit
Re: Springer Tugs
« Reply #1234 on: October 23, 2008, 03:28:13 am »
The 'O' Type....
It has advanced quite a lot since the last update...  :embarrassed:
The bottom has been added as well as some of the 'guts'. The deck has been roughed out ready for fitting and i have begun work on the superstructure...
Re: Springer Tugs
« Reply #1235 on: October 23, 2008, 07:47:09 am »
Is that 'pimp my ride' - "bling" lights under your springer?!?!!?  :-))
portside II
  • tugs at rest
Re: Springer Tugs
« Reply #1236 on: October 23, 2008, 10:12:28 am »
shoudn't the green lights be on the other side   {-) Mmm multi coloured could be a disco springer  ;) .
daz
toesupwa
  • USA'd ex Brit
Re: Springer Tugs
« Reply #1237 on: October 23, 2008, 10:57:14 am »
OH yeah... sorry Portside...  :P
andyn
Re: Springer Tugs
« Reply #1238 on: October 23, 2008, 01:44:41 pm »
Paint it black, have some christmas tree mirror balls inside, some black lights with stuff written in uv pen, and some loud thumping music from inside....
RAVE SPRINGER!!!!!
Some inspiration - Cyberdog in Camden
www.cyberdog.net
Andy ok2
portside II
  • tugs at rest
Re: Springer Tugs
« Reply #1239 on: October 23, 2008, 02:08:00 pm »
I like it  :-)) , one thing mr toes ,how do you get your cuts so clean .
I have seen some of your work  and the work involved if i was doing it ,well it would take me forever to make all those cuts.
Whats your secret.
daz
amdaylight
Re: Springer Tugs
« Reply #1240 on: October 23, 2008, 04:47:01 pm »
So how are you going to make the outboard motor work? ? %) O0 :-))
Andre
over yonder in Portland Oregon
toesupwa
  • USA'd ex Brit
Re: Springer Tugs
« Reply #1241 on: October 23, 2008, 06:47:03 pm »
... one thing mr toes ,how do you get your cuts so clean .
Whats your secret.
No Secret..
A sharp modelling knife, a steel rule, a set of needle files for finishing off.. and patience.  :embarrassed:
toesupwa
  • USA'd ex Brit
Re: Springer Tugs
« Reply #1242 on: October 23, 2008, 06:49:39 pm »
By sending it out on a paper round next week...  :P
It doesnt 'work' as an outboard Andre, its a block of wood attached to the rudder...  :D
amdaylight
Re: Springer Tugs
« Reply #1243 on: October 23, 2008, 09:26:04 pm »
I like it, I had a good laugh  {-) O0 {-) O0, Thanks, by the way how's the "J" Class Springer coming along ?
Andre,
portside II
  • tugs at rest
Re: Springer Tugs
« Reply #1244 on: October 24, 2008, 12:49:31 am »
No Secret..
Ah patience  can you get that in a 250ml bottle , or is it only in 500ml size  :}  :}
daz
toesupwa
  • USA'd ex Brit
Re: Springer Tugs
« Reply #1245 on: October 24, 2008, 03:08:37 pm »
.. by the way how's the "J" Class Springer coming along ?
Its on stop at the moment while i do some to the 'O' type... and do some thinking about how to put it together...
The 'J' Type construction will resume shortly..  ;)
I thought it was only available in 'Buckets'...  :embarrassed:
toesupwa
  • USA'd ex Brit
Re: Springer Tugs
« Reply #1246 on: October 28, 2008, 04:35:03 am »
The 'O' Type.
The deck has been roughed out ready for final fitting...
Some color has been added to the superstructure and some of the wiring is being added ready for the lighting.
The 'Outboard' has had some paint.. but needs another coat of clearcoat now the letters have been added.
I'm still awaiting some 'U' joints before i can finish the installation in the hull and add the deck 'proper'.
ray123
  • shuswap tugboat
Re: Springer Tugs
« Reply #1247 on: October 28, 2008, 10:04:54 pm »
 looking good toesupwa   good job :-)) :-))
toesupwa
  • USA'd ex Brit
Re: Springer Tugs
« Reply #1248 on: November 01, 2008, 04:19:45 am »
All of the wiring has been completed and tested..  :D
Now its a strip down and complete the hull.
Arrow5
Re: Springer Tugs
« Reply #1249 on: November 03, 2008, 09:17:47 pm »
Some early snow on the Cairngorms and a calm Loch Morlich , natural light of course :P
Pages: 1 ... 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 [50] 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 ... 75   Go Up
