Author Topic: Springer Tugs  (Read 957202 times)
tugboyben
Re: Springer Tugs
« Reply #1300 on: February 22, 2009, 08:43:11 PM »
hi chingdevil
i do not no if the 777 have more power than the 540 motor but i will only be running on 6volt hope that it will be ok i will get back to on that one as for the coaming it will be 30 to 40mm high i do not realy wot a sub thanks for the help
regards jason  :-))
chingdevil
Re: Springer Tugs
« Reply #1301 on: February 22, 2009, 09:40:53 PM »
Hi Jason
Mine only runs on 6 volt, I have two 6volt 4ah SLA's useful as ballast. They are wired in parallel to get the best run time for the springer.
Brian
toesupwa
  • USA'd ex Brit
Re: Springer Tugs
« Reply #1302 on: February 23, 2009, 04:24:56 AM »
parts list
model motors direct 777
robbe 50mm kort nozzle
hitec servo
7 inch prop shaft
45 mm 4 blade prop
speed controller
If those are Proboat ESC's you may want to reconsider using those...
They are not known for their low end speed and seem to cut in at about 1/3rd throttle...
Mtronics are much better at low end speeds.
Looking good though Tugboyben  :D
tugboyben
Re: Springer Tugs
« Reply #1303 on: February 23, 2009, 06:21:31 AM »
hi toesupwa
thanks for that i have two mtronics 15amp speed controllers i can give them ago when i get them on the water :-))
regards jason
tugboyben
Re: Springer Tugs
« Reply #1304 on: February 23, 2009, 07:16:33 PM »
hi all
well moving a long with the build props & kort nozzles guled in i got my hands on some more motors mfa torpedo 500 6:1 ratio the output of the motor at @ 6v 1316 rpm & output @ 12v 2633 rpm wot do u think i will be happy for the comments
regards jason
Bill D203
  • not long now!!
Re: Springer Tugs
« Reply #1305 on: February 23, 2009, 07:47:42 PM »
Tell me are they easy to make. Could make a change from my normal go nuts out Makara and Hydro.
Could be a bit of FUN???
craftysod
Re: Springer Tugs
« Reply #1306 on: February 23, 2009, 07:50:09 PM »
Bill
They are really easy to make,if i can do it anyone can
Mark
tugboyben
Re: Springer Tugs
« Reply #1307 on: February 23, 2009, 08:51:36 PM »
hi bill
very easy build go on build one i have only got 5 hours work in two i no a long way to go motors will be in tomorrow i hope i can't wait to get started on the super structures :-)
regards jason
Bill D203
  • not long now!!
Re: Springer Tugs
« Reply #1308 on: February 23, 2009, 10:25:17 PM »
Yes Cheer for all the encouragement. May be I will get round to it soon. Watch this space???
portside II
  • tugs at rest
Re: Springer Tugs
« Reply #1309 on: February 23, 2009, 10:48:25 PM »
Theres nowt wrong with 12v , thats why there are two 6v bats in mine .
Plug and play create havoc %%
daz
I like to build my boats to play with, not to just look pretty,so they dont !
andyn
Re: Springer Tugs
« Reply #1310 on: February 23, 2009, 10:50:33 PM »
Bill, shall we do the NitroSpring? I've got an engine for it...
Bill D203
  • not long now!!
Re: Springer Tugs
« Reply #1311 on: February 23, 2009, 10:54:56 PM »
Hi Andy
Im doing nothing for a bit. you know why. Just an Idear at this stage. See what bits I can get in HK.
andyn
Re: Springer Tugs
« Reply #1312 on: February 23, 2009, 10:59:17 PM »
Fair does. I expect I'll be able to nab borrow some suitable ply from school
tugboyben
Re: Springer Tugs
« Reply #1313 on: February 24, 2009, 07:49:32 PM »
hi all
got a bit more done today finished the props  korts nozzles on to the motors mount made servos for the korts nozzles & fit batterys tomorrow
regards jason :-))
Bill D203
  • not long now!!
Re: Springer Tugs
« Reply #1314 on: February 27, 2009, 06:52:10 PM »
OK so it's time to own up. I thought I should give this Tug biasness a go in time for Wicksteed park.  I was not sure on the power plant? Then hiding under my bench this old engine. With a little bit of work i got it back to life. As you can see I have lots to do. Should be good for Wicksteed Mayhem.
craftysod
Re: Springer Tugs
« Reply #1315 on: February 27, 2009, 08:04:05 PM »
Bill
I always thought you fast boys are nuts,no you have confirmed it  :}
Mark
Arrow5
Re: Springer Tugs
« Reply #1316 on: February 27, 2009, 08:21:08 PM »
Ah, the fastest submarine in Christendom.  You could have waited till April 1st {-) {-) {-) {-)
..well can you land on this?
tugboyben
Re: Springer Tugs
« Reply #1317 on: February 27, 2009, 09:13:00 PM »
hi bill
WOW I LOVE IT PICTURE PLEASE WHEN U GET ON THE WATER  {-) {-) {-)
REGARDS JASON
toesupwa
  • USA'd ex Brit
Re: Springer Tugs
« Reply #1318 on: February 27, 2009, 09:18:25 PM »
I'm trying to think of a word...
Ummm...
Ummm...
'Nuts'  {-) ... that will do for now...
Bill D203
  • not long now!!
Re: Springer Tugs
« Reply #1319 on: February 27, 2009, 11:46:14 PM »
OK All i can say " IT HAD TO BE DONE" :-))
omra85
Re: Springer Tugs
« Reply #1320 on: February 28, 2009, 10:11:42 PM »
Hi Bill (you nutter) - how about a "tunnel hull" springer?  You need something on the front to keep it up  %)
Heavy duty swivel push arms (don't know the techy name?) which lower into the 'tunnel' position.
Precision drawings below. Easy!
Glad to see your keeping the mad good name of IC alive and well  %% %%
Danny
Tugboat Andy
Re: Springer Tugs
« Reply #1321 on: March 01, 2009, 02:33:54 AM »
hi all
regards jason
Jason
I run a couple of my Springers with the Robbe Navy motors geared 5:1 turning a 50mm prop inside a Robbe kort nozzle. I have been very happy with this combination at 6 volts. Lots of precision control :-)) However, I do not have the full skeg that you show on your boats. Looking good!
Best regards
TBA
Re: Springer Tugs
« Reply #1322 on: March 01, 2009, 03:19:47 AM »
Well Chingdevil I bet you will have met your match with Bill's creation
Stav
tugboyben
Re: Springer Tugs
« Reply #1323 on: March 01, 2009, 07:51:56 AM »
hi tugboat andy
thanks do you have some pictures of your springers i will post more picture soon of my build  :-))
kind regards jason
chingdevil
Re: Springer Tugs
« Reply #1324 on: March 01, 2009, 11:26:51 AM »
Stav
You could be right there, but I want to see it run before I worry too much. Not much of a coaming and a very big opening, the word "Dive, Dive, Dive" spring to mind :-)) :-)) :-)) :-)) :-))
Brian
Pages: 1 ... 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 ... 75   Go Up
