Guys.....just thinking.......the principal of using a lock nut is simple
1. a nut can be positioned at
any given point on a threaded shaft
2. we introduce a second nut and apply a torsional moment between the two nuts [holding each nut with a close fitting spanner] and tightening toward each other
3. in effect we are stretching the threaded shaft....however we must not exceed the yield point value of the
shaft material as if that happened the shaft would fracture & split
4. placing Loctite is a form of insurance, however it is the induced torque applied between the two components that locks them to the shaft
5. we can consider the propeller tapping to be one nut....the other component is the lock nut
6. the difference in the length between the propeller tapping to the nut length has no influence ...again it is the induced tension between the two components
7. in an extreme overkill...if each component were tightened against each other beyond the shaft materials yield point..........the component with the shortest thread form length [the nut] would have caused the yield failure
Now the alternate to this is locking the propeller against a shoulder on the prop shaft & installing a lock nut.........however the same principals apply.......stretch the shaft thread
As I am sure many would understand cylinder heads on large marine diesel engines are secured by hand and without a lock nut
as the cylinder head studs [160 diameter?] are hydraulically stretched....the nut engaged to seat & the hydraulic tension on the stud released
....same principal
For my money...........if you install the prop & locknut as per the points above ...they will never move........
.....Derek
