April 25, 2024, 09:55:44 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Tugs and Towing
Further question on Rudders
« previous
next »
Pages:
1
2
Go Down
Print
Author
Topic: Further question on Rudders (Read 7526 times)
tugmad
Guest
Re: Further question on Rudders
Reply #25 on:
January 12, 2012, 08:18:20 pm »
That is a nice installation you have there.
Full Mayhemer
Offline
Newport. S Wales
Reply #26 on:
January 12, 2012, 08:57:44 pm »
I agree. Quite beautiful. Should be easy to re make my drive system as this is obviously the way to go. Mind you, moving the tubes down into line could be fun.
75 mm props at 4 blades as well. I am impressed. You've re-rejuvenated an old man.
Thank you for showing us.
Ken
Despite the high cost of living .......... It remains popular
787Eng
Guest
Reply #27 on:
January 12, 2012, 10:31:22 pm »
Thanks Both for the kind words....
Kenny, how Ive removed epoxied shafts before was to cut the tube almost flush with the hull on the outside and then heat up the remaining tube with a solering iron shoved up the tube. Then with a big pair of pliers on the inside, start by gently twisting, eventually the heat will soften the epoxy and out the shaft pops....
The shafts I used were the MMM 10" x 5mm ones, with the matching heavy duty A frames in the positions marked on the hull...
Brive belts were from
http://www.motionco.co.uk/timing-pulleys-timing-pulleys-aluminium-c-25_35_50.html
but were modified to remove the mounting hub.
Mark
Full Mayhemer
Offline
Newport. S Wales
Reply #28 on:
January 12, 2012, 10:38:02 pm »
Once again, brilliant information. I shall get on it when the "Yard" is clear.
Thanks,
Ken
787Eng
Guest
Reply #29 on:
January 12, 2012, 10:44:18 pm »
Kenny the belts are motionco P/N B3M065.
They also have a very nice belt length calculator if you wish to play with the ratio's...
Mark
farrow
Guest
Reply #30 on:
January 14, 2012, 03:28:19 pm »
Hi Kenny, seems 787Eng has solved your problem, looks a nice system.
Print
Pages:
1
2
Go Up
« previous
next »
Tugs and Towing
