Author Topic: Vladyka MTB 67 build  (Read 15636 times)
Blackadder
« on: January 16, 2012, 05:03:40 pm »
Hello!
I'm Thomas, I'm eleven years old and for christmas I got a Motor Torpedo Boat for christmas and my Dad thought it would be a good idea to put my progress on this site.
First of all we drilled out the rudder and the prop shaft.
After doing this we put in the rudder tube.
Then I fitted together the drive system, before fitting it into the boat to see how it fitted.
This is the boat with all the components fittted . I did all of this myself .
More post coming :-))
TailUK
Re: Vladyka MTB 67 build
« Reply #1 on: January 16, 2012, 05:17:38 pm »
Nice work, a neat job!
« Reply #2 on: January 16, 2012, 08:36:38 pm »
Hi Thomas and welcome to Modelboat Mayhem.
It's nice to see your build on here. Please keep the pictures coming as we are all interested in your build.
ken
pettyofficernick
« Reply #3 on: January 17, 2012, 12:51:11 am »
Good work! :-)) :-)) :-))
rmaddock
« Reply #4 on: January 17, 2012, 08:11:11 pm »
Thanks for the comments!
After doing this we tested that the servo fitted(it did)before screwing it in and bending the push rod to fit the angle.
When this was all correct we used some epoxy filler to strengthen everything, it also helped with waterproofing the prop-shaft.
    In the photo there is a wooden bar at deck level. In the plans this was not there and instead there were these small triangles, however when I tested that they fitted they were off by quite a bit, so I reasoned that we should put some beams across instead as even if they were the right angle, they are not big enough!
This is how it stands at the moment, I have ordered a battery pack and speed controller.I never really realised how much this stuff costs! >:-o
More posts coming :-))
Whoops! logged on as my Dad :o :o :o
Welsh Wizard
« Reply #5 on: January 17, 2012, 09:37:07 pm »
Excellent work it is so nice and refreshing to see a young modeller doing an EXCELLENT job keep up the good work
« Reply #6 on: January 21, 2012, 04:30:45 pm »
I agree with what WW said  :-))
 hey - have you thought about choosing your Avatar yet?
fletch62
« Reply #7 on: January 21, 2012, 05:18:03 pm »
good job keep the pictures coming
Blackadder
« Reply #8 on: January 21, 2012, 07:19:42 pm »
Hi again,
Do you like the avatar? I drew it myself, it's a member of the anti teddy squad!!!%%
Anyway, as for the build:
The ESC and battery arrived in the post a while ago and today we went into Barrow so I got LOTS of money from the bank to pay my dad back.
      When we got back We fitted the ESC and battery together with everything else. Here I am testing everything, It worked :} :} :} :} :} :}.
Now, after having the wooden beams in the hull at the same time as the servo arm we found it didn't quite fit {:-{. So my dad whittled away a gap in the wood so that it fits.
You may have noticed in the picture before this that the deck has been put on! We did this with epoxy resin after roughing up the plastic with sandpaper so that the glue stuck properly.
      While the glue dries we have got sellotape holding it in place.
Blackadder
« Reply #9 on: January 23, 2012, 07:55:19 pm »
Hello :-)
Recently I have put on most of the parts that go on the deck that are going to be grey like the hull.
First I did the parts at the front of the boat.Then the pieces around the edge after that I assembled the torpedo tubes by wrapping masking tape around them, then running plastic adhesive down the inside. I then took the tape of and have fitted everything on.
This morning i made some makeshift barrels for my guns as we couldn't find the one that came with the kit....... %)
Anyway It is coming along nicely and,
« Reply #10 on: January 23, 2012, 08:14:01 pm »
TJ
You are doing a fine job.
Watch out for the guy in the blue sweatshirt
He's after the boat  {-)
Blackadder
« Reply #11 on: January 30, 2012, 08:27:09 pm »
Nah! he has his own!
Now, I have glued the deck onto the hull and have painted the whole thing grey! We have fitted some of the many small details onto the boat's superstructure.
Here I am drilling holes into the plastic superstructure, wood drill bits seem to do and excelent job at a neat hole.
This is the boat whenit is painted grey {:-{, doesn't look quite right...
...there you go much better after a nice green coat :-)) :-)) :-)).
More post coming :}
« Reply #12 on: January 31, 2012, 02:10:00 pm »
Hi Thomas
Yep - bit of colour brings it to life - nice clean line too. :-))
Just love those gloves - mine are falling to bits - might buy
some like those just to puzzle Swmbo. %%
Has the lost gun turned up yet?
Blackadder
« Reply #13 on: January 31, 2012, 06:19:38 pm »
 Well it wasn't the actuall gun just the barrel, I used some plastic leftovers instead.
As for the gloves I got those for a pound in the market!
tjm :-))
Blackadder
« Reply #14 on: February 24, 2012, 04:31:55 pm »
Ok I haven't posted for a while, but here is a list...
Here it is with;
the cabin, with windows.
all the small parts on the deck fitted.
the bits of wire
and fully painted!
It floats! we filled the bath to test.
http://youtu.be/5iyiYFERfos
there is a link to the U tube video with it on.
You may notice that the pole on the front is no longer there on the video, well my dad got it out of the car and snapped it off! (I think it actually looked better! :})
And there you go my second ever boat finished!
Thanks for the support,
tjm :-))
« Reply #15 on: February 24, 2012, 04:43:37 pm »
Well done TJ
Definitely a list on the seat
Watch out for the jellyfish in the test tank
Looking forward to your next build
« Reply #16 on: February 24, 2012, 04:55:08 pm »
Very enjoyable TJ and she moves well.
Was that your choice of music?
Are the wires fixed? or can they come out?
On another thread I read that they had put
small springs in first and then attached the
wires to the springs - less chance of damage.
It's something I am going to remember for
the future anyway.
What's next?
Blackadder
« Reply #17 on: February 24, 2012, 05:11:14 pm »
Thanks!
As for whats next I don't have a clue...
The music my dad found on U tube and thought it was the right length and ok so...No i didn't choose the music.
tj :-))
ggeorge
« Reply #18 on: February 25, 2012, 12:44:12 am »
Hi From  Canada,
  It is a real treat to see a young person in the hobby.  Great build and looking foward to the next build.
 G. George
cuppa
« Reply #19 on: February 26, 2012, 06:15:57 pm »
Very nice work Thomas. You have made an excellent job of the build. A model to be very proud of.
lakesidebob
« Reply #20 on: August 15, 2013, 03:39:26 pm »
Based on this excellent build log,over a year ago i see [have just stumbled on it],i have ordered one,is just what i have been looking for.Size,price,ABS Hull,and well done to the young man.Wonder what his next project was/is.Bob.
Harquebus
« Reply #21 on: August 17, 2013, 12:27:36 am »
I stumbled upon it too; thanks to you, lakesidebob:-)
I was wondering about the kit. Who makes it?
~Harq
lakesidebob
« Reply #22 on: August 17, 2013, 12:34:33 am »
Good to see someone else has found what they are looking for Harq!Try www.puffinmodels.com  Ordered mine yesterday. Any problems get back to me.Good Luck.Bob.
« Reply #23 on: August 17, 2013, 12:49:05 pm »
If you'd looked here :- http://www.modelboatmayhem.co.uk/forum/index.php/topic,44382.0.html it would have been easier to stumble on.
lakesidebob
« Reply #24 on: August 17, 2013, 11:29:46 pm »
Actually,i did start there...but thankyou.
