Author Topic: Servo direction  (Read 4475 times)
colin
Servo direction
« on: January 19, 2012, 08:12:28 pm »
The 2 servos in the centre of the model i need to turn in opposite directions of one channel via a y lead. Is it just a case of reversing the one plug or will this damage the servo.
Born free Taxed to death.
CF-FZG
Re: Servo direction
« Reply #1 on: January 19, 2012, 08:22:04 pm »
You could do with a reversing Y-lead - not 100%, but I think it might be Ripmax that sell them.
Yes, just turning the plug around will kill the servo, (that's if you can get it to fit :-)
Mark.
CF-FZG
Re: Servo direction
« Reply #2 on: January 19, 2012, 08:23:55 pm »
Ideally you would use 2 seperate channels and slave on to the other using a mix, (reversing 1 channel in the process), but if you can't do that then you could do with a reversing Y-lead - not 100%, but I think it might be Ripmax that sell them.
Mark.
Umi_Ryuzuki
Re: Servo direction
« Reply #3 on: January 20, 2012, 12:36:08 am »
You can purchase "in line" servo reversing circuits.
http://www.servocity.com/html/sr10_servo_reverser.html
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=Servo+Reverser&search=Go
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=17033
If you wanted to hack the servo, you have to reverse the motor leads, and now a days that
often means de-soldering the motor from a circuit board. Also, you have to reverse the outside leads
to the potentiometer inside.
Re: Servo direction
« Reply #4 on: January 20, 2012, 10:38:44 am »
Is there an over-riding reason why two servos are needed?  It sounds like the two are sited adjacent to each other, and going to be pulling/pushing in the same direction off the same signal, so one servo and a mechanical split would seem more practical.
roycv
Re: Servo direction
« Reply #5 on: January 20, 2012, 01:42:53 pm »
Hi, I remember when servos could be left or right turning, have they stopped doing that now?
Roy
john s 2
Re: Servo direction
« Reply #6 on: January 20, 2012, 06:34:46 pm »
Is it possible to simply move the link to the other side of the sevo so reversing direction? This may also involve altering the throw. John.
ACTion
Re: Servo direction
« Reply #7 on: January 20, 2012, 06:44:22 pm »
Roy
Yes.
Yes but it will clash mechanically (as shown).
DM
colin
Re: Servo direction
« Reply #8 on: January 20, 2012, 06:46:59 pm »
Thanks for all the replies had a look at the reversing leads but expensive. After reading replies i think i will go with Johns suggestion My reason for the two together just seemed obvious at the time and then you get blinded by your own line of logic. Again thanks to all.
Regards Colin
colin
Re: Servo direction
« Reply #9 on: January 31, 2012, 07:35:16 pm »
Sorted the servo positions out now need to tidy up wiring now i know it works thanks for the replies.
