New to this forum, and to model baot building, but built may RC scale aircraft, and a couple of steam locos.
Anyway
want to build a Mersey tug (just moved away from Merseyside, so need a link back to my roots)
I have the plans for Throstlegarth, at 1:32 scale, and have a few questions;-
1 Is this model the same or very similar to Fleet Mounts" Bangarth", and Model Marine Models "Rosegarth"
If so, can I get some bits from these people, to help with my plan build
2 Building off the plan, can I just cut all the ribs from 1/8 & 1/4 inch marine ply(Think you call them frames), from the plan, glue them onto the keel from 1/8 inch ply (with a key in each to lock), add a few stringers (Model aircraft term) 1/4 square balsa to hold or link the frames, then sheet with 1/16 inch or 1/32 inch ply sheet, maybe small sheets to simulate the metal sheets
3 Is there any differneces with each of the sister boats, AysGarth, Applegarth, Grassgarth, Rosegarth, Bangarth
4 any advise on build this, tips, motor, prop, anything!!!!
