Author Topic: Multi ? Build  (Read 3818 times)
Flash22
Multi ? Build
« on: January 29, 2012, 02:54:47 pm »
Got this off ebay its in a bit of a mess not sure what it is yet but it had sgh marine stickers on it, the motor is a ops .40 with good compresion but it could do with a rebuild (£120 in parts alone)
I may convert it to electric i then have more places to run more of the time, drive is currently submerged i was thinking about going the surface route but it all comes down to money
click on the pics to see them bigger
MikeA
Re: Multi ? Build
« Reply #1 on: January 29, 2012, 03:50:50 pm »
hi flash welcome to the forum just had a nose through your new found collection of boats. This looks like an FSRV race boat, could be wrong though.  :P
Flash22
Re: Multi ? Build
« Reply #2 on: January 29, 2012, 05:02:54 pm »
thanks for the reply, been working on the boat today trying to work out why its so heavy....................
2kg lead weight in the stern and a 1" deep of body filler 12" long
Got to take out the prop shaft as it more worn than i thought got to dig all that filler out to get at it, I can see a a few hull repairs coming
gwa84
Re: Multi ? Build
« Reply #3 on: January 29, 2012, 06:05:54 pm »
hi and welcome to the forum the boat is a FSRV multi boat and is supposed to have conventional drive not sure haw well serfice drive would work on a multi boat these boats where designed primeraly for cornering speed as they tend to do ther serkits flat out without slowing for the corner the weight in the boat could of been to correct some instability problems maybe had to big an engine in her overpowering the hull good luck with it ime sure there will be more info coming soon  :-))
just an idea of what these boats do  :-))
http://www.youtube.com/watch?v=-qRq7n-0Bow
MikeA
Re: Multi ? Build
« Reply #4 on: January 29, 2012, 08:24:40 pm »
at a guess i reckon the additional ballast would probably be to bring it up to class regulation weight. Do you know how old the boat is?
It might still be within FSRV regulations.
gwa84
Re: Multi ? Build
« Reply #5 on: January 29, 2012, 09:43:51 pm »
Flash22 you have a pm bud  :-))
Flash22
Re: Multi ? Build
« Reply #6 on: January 30, 2012, 11:26:31 am »
The ops 40 is rear carb front exhaust. the engine mounts are cast alloy made be Weston but i cant find any info on this mount.
I think i may strip the hull and start again as the hull has lots of body filler
imo the hull maybe SHG marine laser its  just under 4ft with 18" beam or so
Flash22
Re: Multi ? Build
« Reply #7 on: January 30, 2012, 06:13:26 pm »
well todays efforts inc removing 2 tank supports and 3 engine mounts, what a pain thay had a layer of fibreglass with a ton of body filler what the mounts had sqidged into while wet what a mess, the body filler is porus so has taken up some mosture other part are rock hard either way its a mess
tomorrows job is to get the last mount out and cut, sand and obliterate  the rest of the filler
MikeA
Re: Multi ? Build
« Reply #8 on: January 31, 2012, 12:58:05 am »
sounds like a right state :o
Flash22
Re: Multi ? Build
« Reply #9 on: February 02, 2012, 01:14:19 pm »
A little update..........
finally started on stripping the hull out but turned into a nightmare the lead has now gone iam slowly removing all the damn body filler as a result i have put a quite a few holes in the hull but nothing a bit of chopped mat and resin wouldnt cure
still got all the filler where the front mounts where to remove and tidy is all up
gwa84
Re: Multi ? Build
« Reply #10 on: February 02, 2012, 03:09:14 pm »
not to bad underneathe like you sead nothing a bit of fibre wont sort
Flash22
Re: Multi ? Build
« Reply #11 on: February 03, 2012, 06:17:29 pm »
The inside is now glassed (run out of resin) the hull botton has been filled flatted and filled again but needs flatting again
Got a feelng this is going to be a long project, new brushless motor, mount and esc, custom motor cooling
120-140A esc should do the trick with a 2-3000kv 48-70 motor
The ops .40 will get a full clean once i get the flywheel off with a puller (hopefully be borrowing a puller tomorrow) that will go up for sale with the pipe and the weston engine mount  ok2
gwa84
Re: Multi ? Build
« Reply #12 on: February 03, 2012, 08:12:41 pm »
let me know haw much for the engine bud could do with it for sper parts to sort mine out  :-))
Page created in 0.491 seconds with 15 queries.
