Author Topic: make a simple crane for your crafts..  (Read 6856 times)
rathikrishna
« on: February 04, 2012, 04:08:04 pm »
Friends..there must not be anyone, who like to fix a working crane to his or her's craft..but all we know even a smaller working crane is very expensive..so, it is not feasible to sit up, like a cat sitting in front of a meat shop, with mouthful of water..so, turn to work table..its all easy..all we know, a basic 4 channel radio is far enough for ship and boat modeling, as we can use the two channels as throttle and steering, while other two can use to blow a horn, switch on a light or to control a thrust pump..but if it goes to a 6 channel, it will be even better..nowadays a 6 channel radio is far inexpensive than a mobile phone..but, usualy, two of our channels always kept free of use..so, its time to think about a simple but effective working crane..and it will be very interesting to see, while in operation at water..cool..and inspiring..
and now, all we know the micro servos are even inexpensive, so it is so inexpensive than a EP 30 gearbox..but works well..so, what we need here to make a working crane..?  only two micro servos, for scale from 1: 48, 1:35, 1:28,and 1:26th..but can use standard servos for bigger scale and heavier applications..here we are using the unsued two channels of our radio, or can use any channels up to us..and with a three channel we can also activate the hold mechanism..
so at first we can make a simple crane with two channels..
take two micro servos..any weight and any make..
rathikrishna
Re: make a simple crane for your crafts..
« Reply #1 on: February 04, 2012, 04:12:41 pm »
attach a circular flange to one servo, while attach a star flange to another..
rathikrishna
« Reply #2 on: February 04, 2012, 04:17:15 pm »
make sure the servos are good..we can also power up servos, but here it need not..
Friends...from here all istructions are based on my imaginatios..so you can add anything on your cranes, and in to any shape you desire..the shown roots are only a key..
now take a piece of foam board, in to 2 mm thick..place the servo, while leaving some space all around..mark it..
rathikrishna
« Reply #3 on: February 04, 2012, 04:20:17 pm »
cut it out...neatly..
and check the servo is fit in hole..i have a humble request to you all..is to avoid glueing the servos with glues..will be a mess..
rathikrishna
« Reply #4 on: February 04, 2012, 04:22:54 pm »
now attach a sharp pencil to compass..and draw two outer lines as the inner leaves the servo ears..
rathikrishna
« Reply #5 on: February 04, 2012, 04:24:59 pm »
cut out the circle with sharp scissors..
make sure we have a margin all around...
rathikrishna
« Reply #6 on: February 04, 2012, 04:27:38 pm »
measure the difference between the circular base and flange once..leave 1 mm from this reading..
attach a circle made of paper strip as shown..
rathikrishna
« Reply #7 on: February 04, 2012, 04:30:13 pm »
now draw a circle in foam board, just greater than that of the base we added..
it is the base portion to glue to the servo flange later..
rathikrishna
« Reply #8 on: February 04, 2012, 04:33:02 pm »
take ivory card paper, or thick chart paper, and laminate it in to two or three, or according to your desired thickness..can laminate it with diluted white glue..
rathikrishna
« Reply #9 on: February 04, 2012, 04:37:41 pm »
the thickness of lamination all up to you..but make sure at least two sheets..
now draw outlines of the base of the crane..is only a key..can go in any shape..
rathikrishna
« Reply #10 on: February 04, 2012, 04:41:01 pm »
cut the hole for servo, and make identical two..
place servo as shown..and not from back to in..
rathikrishna
« Reply #11 on: February 04, 2012, 04:43:38 pm »
add a reinforcement attachment with same paper..this acts as a stopper, for servo..and holds the servo in place without a screw..
rathikrishna
« Reply #12 on: February 04, 2012, 04:48:12 pm »
now start to cut the upper boom while keeping the size and scle up to need..
make sure the boom in proportion..
rathikrishna
« Reply #13 on: February 04, 2012, 04:51:26 pm »
make two sides in identical..fix it as shown, and can make in to any shape..
after fixation..add a simple hook from steel wire..
rathikrishna
« Reply #14 on: February 04, 2012, 04:54:01 pm »
now all needed parts are ready..
now a little detailing..cut some end ridges from paper srips..
rathikrishna
« Reply #15 on: February 04, 2012, 04:58:37 pm »
glue the base to the servo flange..and glue all ridges to the base as shown..
now paint it in to any desired color..
rathikrishna
« Reply #16 on: February 04, 2012, 05:01:35 pm »
i painted it in industrial orange..for my Tug..can paint it in any color...
rathikrishna
« Reply #17 on: February 04, 2012, 05:03:45 pm »
fix a brass rod on the opposite side and glue it..after lock it with a piece of a ball point pen refill..
rathikrishna
« Reply #18 on: February 04, 2012, 05:07:40 pm »
now..time to check..i use a 6 channel radio here and connected the two servos to the potentio meters of the Tx, as shown..
and the first pot used to rotate the crane base..
rathikrishna
« Reply #19 on: February 04, 2012, 05:11:15 pm »
while the second pot is used to lift and down boom...
rathikrishna
« Reply #20 on: February 04, 2012, 05:15:59 pm »
look Friends..how easy to make a crane..will it works according to plan..? see a cool video here..
http://www.youtube.com/watch?v=L5LYyZjIovM
rathikrishna
« Reply #21 on: February 04, 2012, 05:19:21 pm »
so what we make next..? a three channeled crane with hold catch and release..then can also make a simple winch for our crafts..boats..SUVs..ships..hoooy..and its time to make more crafts..and be a idea cat..than a mouth watering cat..and string up your guitar..ohhh..gooobttaa...gommmbttaa...krrrriiiiiiiiinnnnnnnnnn.......while the craft goes in water... :-))  have some nice crafts to you all... :-))
rathikrishna
« Reply #22 on: February 04, 2012, 06:02:49 pm »
Friends..i missed one thing to tell you..its not nesseary to connect a radio set, but this crane also can be opertaed by a servo controller circuit..so, can be used in our rail road dioramas..can make this circuit easily..with a NE 555 ic, or with CD 4020..will add the circuit.. :-))
Welsh Wizard
« Reply #23 on: February 04, 2012, 07:16:54 pm »
Absoloutly  FANTASIC and so so simple
« Reply #24 on: February 04, 2012, 08:46:17 pm »
Hello Krishna
Your posts are always clearly explained and useful ideas. Thanks for sharing.
Page created in 0.136 seconds with 21 queries.
