Author Topic: lazer 4  (Read 3336 times)
pipercub1772
lazer 4
« on: February 13, 2012, 11:53:27 am »
Hi , I have a Hitec  Lazer 4 fm   r/c transmiter is it ok to use a Hitec fm dual conversion receiver with it not sure what dual conversion means kind regards Allan
Re: lazer 4
« Reply #1 on: February 13, 2012, 12:05:06 pm »
As long as its on the right frequency, the RX doesn't really care what is doing the transmitting.  The "double conversion" refers to the way the receiver does its job - it is a way of tightening up the tuning to make sure that only the wanted signal gets in.  It does need the proper double conversion crystals.
tr7v8
Re: lazer 4
« Reply #2 on: February 13, 2012, 12:13:48 pm »
Dual conversion sounds like it could be 35Mhz which means it cannot be used in surface craft only aircraft. Dual conversion isn't generally used in boats anyway.
Jim
pipercub1772
Re: lazer 4
« Reply #3 on: February 13, 2012, 12:29:08 pm »
thanks ,it is 40 meg,i think the transmiter has a has the single conversion crystal  not sure about the receiver but i got the receiver and its crystal new  both crystals say  40.685 having said all that the set up works on the bench i just dont want to interfere with anyone at the lakeside regards Allan
Re: lazer 4
« Reply #4 on: February 13, 2012, 12:54:29 pm »
Yes. I had one of these radio too, good set but do a proper range check as my one did have a duff crystal.
unbuiltnautilus
Re: lazer 4
« Reply #5 on: February 13, 2012, 01:29:39 pm »
You can get Dual Conversion Hitec Receivers on 40mhz as well as 35mhz. They are usually  6 channel and higher.
Subculture
    • Dive-in to Model submarines
Re: lazer 4
« Reply #6 on: February 13, 2012, 01:58:15 pm »
Genuine Hitec dual conversion crystals have a blue label on the tab. Single conversion crystals have a green label.
barriew
Re: lazer 4
« Reply #7 on: February 13, 2012, 05:16:02 pm »
And you only need the Dual Conversion crystal in the RX - there are no dual conversion Tx crystals :-))
Barrie
Re: lazer 4
« Reply #8 on: February 13, 2012, 05:20:00 pm »
No such thing as a dual conversion transmitter.
It's the method used to process the received signal.
pipercub1772
Re: lazer 4
« Reply #9 on: February 13, 2012, 07:05:26 pm »
Thanks for the help guys, yes its got the blue  40/meg crystal so i am happy to proceed,just did not want to upset anyone at the waterside once again thanks for you're replyies kind regards Allan
Page created in 0.037 seconds with 21 queries.
