Author Topic: Electronize 43VR problem.  (Read 3360 times)
rayna
« on: February 14, 2012, 02:54:44 am »
Hi I have a set up where the ESC has been running two motors quite happily for yonks. Now suddenly both motors run only flat out forward or reverse and without a neutral stop or any slow speeds.
Any obvious solutions appreciated. i have swapped channels, swapped crystals, checked batteries in TX and twirled the "neutral" and "speed range" screws on the ESC all so far to no avail.
thanks
Rayna
HS93 (RIP)
  • I cannot spell , tough
Re: Electronize 43VR problem.
« Reply #1 on: February 14, 2012, 05:59:49 am »
have you accidentally connected the battery the wrong way? check to see if relay  clicks , disconnect the motors if you cannot hear it.
Peter
rayna
« Reply #2 on: February 14, 2012, 07:52:38 am »
Relay is clicking (changing over) perfectly but as i said there is no stopping or neutral postion just full speed forward or reverse.
rayna
« Reply #3 on: February 14, 2012, 08:33:21 am »
rayna
That leaves the main output transistor dead.  The rest of the circuit seems OK, since the reversing works so the control part is controlling.  A badly overloaded transistor (like feeding a short) will likely blow up, just leaving three legs and a nasty smell.  A transistor running just a bit outside its margins will eventually melt its insides and change its characteristics, in this case its shorted itself out and become a connection.
If you can spot the OD on the transistor, a repair should be possible.  When fixed, a controller for each motor might be the best bet.
rayna
« Reply #4 on: February 14, 2012, 08:48:18 am »
Malcolm, and all. thanks for your input. That answer is what a local lad had suggested so will lift the lid off and get the data. i understand our modellers in Auckland have a stack of the transistors to repair. So thanks again all
regards
Rayna
