Model Boat Mayhem - Forum
Author Topic: what height stanctions  (Read 1333 times)
Ted_H
« on: February 14, 2012, 10:50:18 AM »
I'm building a type 81 Tribal class frigate and trying to scratch build as much as I can. It's been sometime since I  did any building and one or two things have slipped from my memory.
Can anyone tell me the height of the stanctions and handrails in 1/96 scale. I'm thinking about 15mm.. am i correct?
Ted :police:
pugwash
Re: what height stanctions
« Reply #1 on: February 14, 2012, 12:14:39 PM »
Ted Thats too high - most of the commercial stanchions are 11mm above the deck -- 15mm would make them 4.7ft high at that scale.
I only build in this scale and can assure you that the 3 hole offset stanchions are this high.
Geoff
Ted_H
« Reply #2 on: February 14, 2012, 12:25:45 PM »
Thanks Geoff. thats most usefull. (thats 4mm to the foot if I recall?)
I'll bear it in mind you build in that scale I may tap into your knowledge ...my grey matter is lacking a little after being out of building for so long.
Niall
« Reply #3 on: February 14, 2012, 03:39:15 PM »
4mm to 1 foot is 1/76th(OO) scale. 1/96th scale is 3.185mm(1/8") to 1 foot.
Ted_H
« Reply #4 on: February 15, 2012, 10:45:16 AM »
Thanks Niall.. I guess that would be closer to HO scale... the diffrence could be quite a lot if your only 3/4 inch tall !
John R Haynes
« Reply #5 on: February 15, 2012, 12:28:07 PM »
If you need RN stanchions see JRH 499/500/501 at 1/96 at 11mm high in my on-line shop
