Author Topic: Davits - Supplier?  (Read 2980 times)
U-33
  • K-157 Vepr. Akula-11
Davits - Supplier?
« on: February 18, 2012, 03:19:14 pm »
I'm looking for a pair of Davits about 90mm high. Can anyone recommend a supplier please.
Model suppliers that I use always seem to be out of stock.
Thanks.......
Peteg/
Re: Davits - Supplier?
« Reply #1 on: February 18, 2012, 03:36:07 pm »
There are quite a few different davits that have evolved over the years.
We really need to know the type you require or at least the model you
are building.
U-33
« Reply #2 on: February 18, 2012, 04:07:57 pm »
[IMG]http://i1182.photobucket.com/albums/x460/SeaScout1/Davits18-2-12002.jpg[/IMG]
Hello Ned,
This is the boat that I am working on its called a Cynette and here also is a plan drawing of the type of davit suggested.
The Davits are for lifting on and off the dinghy which sits beneath the davits here. I have started making the dinghy
but plans for it are very sketchy but it is progressing sort of.
Peteg.....
U-33
« Reply #3 on: February 18, 2012, 04:16:18 pm »
Well,
Lets try that again - plan drawing of Davits - should have gone with my last posting?
nemesis
« Reply #5 on: February 18, 2012, 04:24:16 pm »
Hi Looks simple enough to make, Get one knitting needle & file it down to the taper you require. Nemesis
« Reply #6 on: February 18, 2012, 04:34:38 pm »
As Nemesis says an old knitting needle or two if you need a pair of davits.
Once tapered put in boiling water and when pliable bend to the correct shape
and let them cool.
U-33
« Reply #7 on: February 18, 2012, 04:41:53 pm »
Yes, you're right , it does look quite do-able with knitting needles! No pulley sheaves though, which look good,
but something to consider- thanks to you both...
PeteG
« Reply #8 on: February 18, 2012, 04:59:14 pm »
http://home2.btconnect.com/dave_watts/Mastman/Catalogues/cat%20feb2011.pdf
Have a look on this site for pulley blocks.
There are others if you do a search but
I have used this guy.
LarryW
« Reply #9 on: February 18, 2012, 06:11:23 pm »
 Hi ,
   easy scratch build , take one styrene rod  taper down  to required dimensions , trace template of drawing onto thick card soften styrene in hot water , use air dryer,
   bend round template, let it cool to shape , punch some small circles out of styrene sheet for  pulleys and rope guides . fix to washer base , paint add cable rigging .
    i use shirring  elastic  give it a try be surprised what you can do and also save money.........Larry...
U-33
« Reply #10 on: February 18, 2012, 06:44:58 pm »
Hi Larry,
I can see from all that work you have done on your boat that you are a
pretty dab hand at making your own parts!
Thanks for the tips.
PeteG.....
Page created in 0.375 seconds with 17 queries.
