Author Topic: prop problem  (Read 1950 times)
morton
prop problem
« on: February 24, 2012, 10:27:27 am »
hi, i have a nylon prop which i want to change to brass,i can not get the prop to unscrew, i think it was put on with some sort of locktight, there is no lock nuts, the prop screws onto shaft,i dont want to damage old prop, as i am might not get a brass prop with the same thread as it is a old model no longer made, the name of the motor launch is neptune, a billings kit launched in 1958,i dont know when they stopped making this kit
Jerry C
Re: prop problem
« Reply #1 on: February 24, 2012, 11:08:52 am »
Hi morton, if you can undo the universal and slide the shaft and prop out a little bit you might be able to apply a bit of heat with a soldering iron to the shaft close to the prop, heat will usually release all but the toughest threadlock , just be careful not to melt your prop, good luck
morton
prop problem
« Reply #2 on: February 26, 2012, 07:50:56 pm »
thanks mermod problem solved, morton.
Jerry C
Re: prop problem
« Reply #3 on: February 28, 2012, 08:00:29 pm »
cool
Page created in 0.723 seconds with 17 queries.
