At little more information on Victor Model Boats - All of their models (about 12 different models) are fabricated from Hi-impact polystyrene, select woods and high quality sail materials. The hull, deck, keel and miscellaneous components are precision molded plastic and are completely trimmed to size and shape for rapid and accurate assembly. Masts are made from Basswood or maple and require only minor sanding before finishing. Sails are sewn from the highest quality sail materials and are completely finished and ready for installation. Each kit contains a complete hardware package. Stainless steel wire is used for rigging the larger models while Dacron line is used for the smaller models. Easy to follow, detailed assembly instructions help the builder through assembly, finishing, rigging, radio installation, and on to your first launch. The complete kits include everything required to finish the models except glue, paint and liquids such as resin or epoxies. The keel configuration on some of the kits includes an assembled keel bulb ready to fill with lead shot, which is also included.
Specifications:
Footy - Weight 4lbs Height 33 3/4" Length 12" Beam 5.92" Sail Area 131 sq in.
V 32 - Weight 6lbs Height 51" Length 32" Beam 8" Sail Area 435 sq in.
