Author Topic: Two rudders or one  (Read 2838 times)
funtimefrankie
Two rudders or one
« on: March 11, 2012, 07:33:54 pm »
Looking at the plan of my next build, Bluebird of Chelsea, it has one rudder and two motors. I'm wondering if  two rudders might be better for control.
I'm not bothered about deviating from the original layout. I'll probably have a mixer for the two motors.
Two rudders or one?
Any thoughts?
Ta Frank
Re: Two rudders or one
« Reply #1 on: March 11, 2012, 07:36:58 pm »
2 rudders will be better for turning circle.
boat captain
« Reply #2 on: March 11, 2012, 07:53:34 pm »
hi
One of the lads in our club Liverpool MBC built his with two rudders and she sails really well.
Joe
triumphjon
« Reply #3 on: March 11, 2012, 10:04:03 pm »
if im building a vessel with twin motora i fit twin rudders , are you lookimg at the original builders plans , or a model makers plan thats been altered ?
funtimefrankie
« Reply #4 on: March 12, 2012, 08:59:30 am »
It's the Model Boats plan, I think I'll go with two rudders no one seems to be against the idea.
« Reply #5 on: March 12, 2012, 10:03:42 am »
The original build article clearly shows two rudders on the model.
Bryan Young
« Reply #6 on: March 12, 2012, 11:01:36 am »
My "Bluebird" (at 1:12 scale)built from the 1991 MB "Super-Plan" has 2 rudders, 2 motors and 2ESCs. Running off a 6v supply I can use 1 battery per motor. At 1:12 scale (50") the total weight has to be under 20lb....hence 6v as the batteries are smaller and lighter than the 12v things. still gives ample running time.
If you choose the single rudder option but retaining the twin screw set-up I would advise having the props turning "inwards" to give better flow over the rudder. With the twin rudder set-up, she will turn on a "sixpence". BY.
Notes from a simple seaman
funtimefrankie
« Reply #7 on: March 12, 2012, 01:38:33 pm »
Not got the Model Boats article(s), just one from Marine Modelling Inter.
Is the MB one from 1991/2?
I think someone in USA is flogging it for about $20 on DVD, on eBay
Bryan Young
« Reply #8 on: March 12, 2012, 01:55:31 pm »
Frankie....
send me your e-mail address and I reckon I can help you out with all you need. BY.
« Reply #9 on: March 12, 2012, 02:43:17 pm »
Hi
just to put MISTER YOUNG RIGHT  once again HE built the BLUEBIRD OF MAYHEM LOOK HERE IS THE PROOF   hahahaaha only pulling your leg Bry - canny  ARIFIX Kit you built - still think the hull should have bean made from wood instead of that fibreglass stuff
aye
john
Page created in 0.428 seconds with 21 queries.
