Author Topic: What I did while Mayhem was away....  (Read 4972 times)
boatmadman
« on: March 22, 2012, 03:28:21 pm »
I made a yoke engine to ease the withdrawal symptoms.
All made from scrap, and no eggs were harmed during construction. :-))
Mad_Mike
  • Lincolnshire
Re: What I did while Mayhem was away....
« Reply #1 on: March 22, 2012, 03:49:23 pm »
does it work?
richald
  • Retired and loving it!
« Reply #2 on: March 22, 2012, 04:06:32 pm »
More like HOW does it work ?
Richard
(working towards his Full Mayhemer badge!)
Senior member of the OGG (Order of the Grumpy Gits)
Membership Number : 002
« Reply #3 on: March 22, 2012, 04:09:09 pm »
I chewed my nails a lot.... and banged my head.....
Nice engine - is it April 1st already?   ok2
boatmadman
« Reply #4 on: March 22, 2012, 04:26:14 pm »
It turns ok, a little tight yet with newness, and I havent quite got the timing spot on yet.
Brownie point to anyone who can work out how it works!  :}
davidm1945
« Reply #5 on: March 22, 2012, 04:34:59 pm »
It goes round and round and in and out......but wassit for?
« Reply #6 on: March 22, 2012, 04:48:08 pm »
http://www.youtube.com/watch?v=hAhMrAJCXmk
Don't want brownie points I like Donuts
U-33
  • K-157 Vepr. Akula-11
« Reply #7 on: March 22, 2012, 04:57:24 pm »
Bad for the figure, old chap...
rmaddock
« Reply #8 on: March 22, 2012, 05:01:47 pm »
I presume the smaller wheel has a pin which engages a vertical slot in the piece which is clamped onto the piston?
« Reply #9 on: March 22, 2012, 05:04:41 pm »
Excuse me Sir
I have a figure like a trawler
Only smaller
« Reply #10 on: March 22, 2012, 05:23:17 pm »
High pressure pump?
boatmadman
« Reply #11 on: March 22, 2012, 05:32:17 pm »
Full points Mr Maddock. :-))
The design is intended to reduce piston skirt wear on the cylinder by doing away with a top end pivot. The piston rod is fixed into the piston.
Its an old design, dont see many of them about now and was origionally a steam engine.
But, whats it for? What is any engine for? Wasting energy, making noise and if you are lucky, doing a bit of work!
Mad_Mike
  • Lincolnshire
« Reply #12 on: March 22, 2012, 06:19:05 pm »
looks just like this blokes engine:
http://www.youtube.com/watch?v=UL3k2wZvHtk
boatmadman
« Reply #13 on: March 22, 2012, 07:24:45 pm »
That's where I got the idea from. Did a bit of googling, found some plans and bobs yer auntie!
Mad_Mike
  • Lincolnshire
« Reply #14 on: March 22, 2012, 08:41:14 pm »
how do the valves work?
boatmadman
« Reply #15 on: March 22, 2012, 09:35:14 pm »
Its a rotary valve incorporated into the crank shaft. The inlet is at the rear between the upright and the flywheel. As the crank rotates, a port is opened to the supply which feeds through drillings in the upright to the top of the cylinder. 180 deg on, the exhaust port opens the drillings in the upright to a vent passing through the centre of the crank to the outside.
irishcarguy
« Reply #16 on: March 23, 2012, 05:46:15 am »
I cried a lot but now that I have seen boatmans engine I am crying some more, not for me you fools, for him & his engine. Mick B.
Mick B.
