yes it was my yacht which capsized , shouldnt have launched it , the waves on canoe lake were around ten inches high , the model got a couple of feet out from the side of the lake & promptly blew over on its side , no amount of rudder would bring it around into the following wind , after around five mins it found a small hole in one of its hatches and sank stern first ! thankfully the rudder got stuck on a silt bank 28 1/2 " below the surface , which kept the first 3-4 " of bow above the surface along with the top 6" of mast . the boat was recovered after around four hours . the only loss has been the 6 v rx battery pack , the switch harness , an S hook which keeps the jib sail to the mast and the rudder blade has bent ! ! i shall be making a new rudder this evening , the boat will be good to sail again . The windscreen of my huntsman ive made a brass frame which holds the glazing in place , with the supports that run down both the inner & outeer sides of the cockpit .
