I have recently rejuvenated a 40-year-old "Moonglow" model with its original Marx Decaperm Special (direct-drive, not geared), by equipping it with 2 x 2S 5000mAH LiPos in parallel and a Tio Marine 15 (i.e. with LiPo cut-off) controller. Unfortunately, with LiPo-mode selected in the ESC, the motor occasionally stutters, like a "misfire".
At Mtroniks suggestion, I have added capacitance at the supply input to the controller and beefed-up the wiring to what I consider to be an extreme degree, but the results are still no good. Three videos from the model boat are now on YouTube to illustrate:
1. Original 14awg Y-adapter for the two large batteries, with single 30A auto fuse in in-line fuseholder, between battery and ESC, and with 10,000uF capacitor connected to back-to-back Deans connectors, connected to the male Deans plug that is soldered to the ESC’s red and black wires.
http://www.youtube.com/watch?v=A_R9sqKAo-g2. 12 AWG Y-adapter with 25A blade auto fuses, one per branch, connected to 2 x 22,000uF 16V capacitors soldered directly across the ESC’s red/black input wires. The fuses were also soldered directly to the thick copper buss-bars connecting the two capacitors. The only detachable connectors were the Deans plugs for the batteries. At 10A motor current, the volt-drop in the leads has been reduced from 93mV, total, both leads, to around 20mV.
http://www.youtube.com/watch?v=Ru7YG1f0MjM . This additional assembly adds a rather undesirable 60g to the model – more than the weight of the ESC.
3. As 2, above, but with the ESC’s LiPo battery protection turned off, i.e. NiCad mode selected. You can just see in the videos a partial reflection of the ESC’s LEDs in the front windscreen, LHS: in this one, the blue LED is not showing.
http://www.youtube.com/watch?v=2r69SuPs_lw . Here, the only unwanted speed fluctuations are caused by debris and weed catching the prop! No “glitches" at all! Total running time was 33 minutes, to avoid over-discharge of the batteries which might normally be expected to run for around 1 hour.
Before it is suggested that I remove the supply fuses in order to reduce the voltage drop a tiny bit more, I would like to reiterate that with a single 5000mAH 2S LiPo connected directly to the ESC, the glitching problem was still evident, at currents of 10A or less, with this motor. It seems to me that, in LiPo-mode, the ESC is responding spuriously to small and, particularly, very brief, dips in the supply voltage caused by motor “noise”. With this in mind, I have tried adding 0.1mH in series with the motor, but got no improvement.
I would like to ask whether anyone has experience of this ESC, combined with LiPo batteries of only two cells? In LiPo mode (blue LED on)? With what motor?
