In the drawing, the plug pins are pivoted on an insulating tube (not shown), and are soldered to the input cables. The pins can be driven by the two ends of a servo arm and move in opposition to each other - all that does is alter the wiring of clips compared to the pins moving synchronously...
But, of course, you cannot be sure that the pins will disconnect at
precisely the same time from each clip - in theory a servo failure when only one was disconnected would leave the ESC in a dangerous state....
What I meant was - on a forward only ESC, "off" is commonly "left stick as far back as it goes". A reversing pulse would be given by driving the associated servo beyond that point momentarily.
Sorry - didn't understand. Yes that would work...
A knife switch does benefit from long leaves on the sockets ...
..And you do get the benefit of an Igor (Yes, masterrr) ...
but I wonder what boats would benefit? Fast boats usually perform badly in reverse.... I suppose a cheap springer..... ?
The advantage of a 'U' shape is that you could limit the reverse speed by shortening one arm - here's a paper template example...
