Author Topic: Planet T5 Rx Voltage  (Read 2981 times)
Marc st Hilaire
« on: April 07, 2012, 05:36:54 pm »
Just a quick question, I hope!
I was planning to power a model boat using a 7.2v R/C car power pack: my son has several 7.2V 5300 mAh NI-MH sticks. The question is, using the BEC of the Viper Marine 15 ESC, am I going to wreck the receiver? The handbook says 4.8 - 6.0 V but surely there must be a bit of leeway. Has anyone tried this and got away with it?
Thanks.
Chris.
triumphjon
Re: Planet T5 Rx Voltage
« Reply #1 on: April 07, 2012, 05:41:49 pm »
im sure the bec is set at 5 volts , so shouldnt cause any problems , ive got a couple of boats which have mtroniks esc and run in this manner without any problems
AlanT
« Reply #2 on: April 07, 2012, 05:44:22 pm »
Both my boats run with this same setup, with no problem. I also think the rx batt output from the esc is set around 4.5/5 volts.
Alan
Marc st Hilaire
« Reply #3 on: April 07, 2012, 05:55:37 pm »
Yes. Thanks for this. There is quite a lot about this subject on other threads: should have looked first!
Thanks again.
Chris.
Marc st Hilaire
« Reply #4 on: April 13, 2012, 01:32:48 pm »
Just set up my equipment and gave it a try. With an input voltage of 7.44 Volts the Viper 15 ESC has an output voltage, to the Rx, of 4.95 Volts. So it does work! :-)
Thanks.
Chris.
Page created in 0.35 seconds with 17 queries.
