3 channels will suffice for any multimasted ship, 2-masted schooner to 4-masted barque, anyway: rudder, foremast, main+mizzen (or main+mizzen+jigger for a 4-masted barque). For sails, the rule is: 1 channel for masts forward of the CLR (center of lateral resistance), and 1 channel for the sails aft of the CLR. This allows you to use the sails to steer, a very necessary requirement if you want to both tack and wear, in my experience. Multimasted ships are not as rudder-dominated as sloops; you can't, under all wind conditions, simply jam the rudder over to head up or fall off. It's the misunderstanding of this point that has given the multimasted ships such a "hard-to-sail" reputation, I believe. They work just fine if you follow the rule I've given, and if you adjust sail area to match the wind conditions.
I've gotten away with 2 channels for a bottle boat 2-masted topsail schooner, but that boat requires more microseamanship (and luck with weather) than the 3 channel versions of sailboats. She sails, but her maneuevering is not as elegant as the 3 channel ships.
I don't think that 2 channels would suffice for a barquentine, Mr. Positive (love your miniatures). Fixing the main and mizzen sheets, and only rc-ing the foremast squares, will make it hard to wear ship, or make a run. Going to windward (with tacking) is all fun and good, but at some point in your cruise, you have to sail back downwind to your starting harbour
My ships (gaff sloop, topsail schooners, brigantine, brig, 4-masted barque) can be seen here under my pre-mayhem-crash screen name of Brooks, or over on rcgroups.com (sailboats and scale sailboats forums) under Brooks.
