Author Topic: TX  (Read 6956 times)
gary r uk
TX
« on: April 08, 2007, 03:35:43 pm »
Hi guys
Can some of you help me i have a Futba 6 channel TX & it has a knob on the top right what channel does this knob work from in the RX
cheers
gary rowe
SAILING WITHOUT FAST ELECTRICS PRICELESS
Tug
Re: TX
« Reply #1 on: April 08, 2007, 03:57:44 pm »
5 or 6
Junk is something you've kept for years and throw away three
 weeks before you need it.
gary r uk
Re: TX
« Reply #2 on: April 08, 2007, 04:45:50 pm »
Tug
cheers
i will try that 2nite
gary r
Re: TX
« Reply #3 on: April 09, 2007, 11:43:30 am »
Gary
I have a SkyPort 6 with a knob on the top right of the panel which is labelled Ch 6 Flap. It allows a proportional turn which stays where it is left. There is also a switch top left which is labelled Ch 5 Gear. It gives absolute movement and also stays where it is left.
HTH
Doug
gary r uk
Re: TX
« Reply #4 on: April 09, 2007, 05:44:19 pm »
Doug
thanks
Since buggering up the esc on the Tuesday nite sail i have burnt out another as well ,bover .
i have put in a known to work electronize esc from another vessel and it did F&^K all narder nuffick zilch.
and on top of that the pump in the koi pond stopped working as well so i am running on the spare , still 6 years of uninterrupted service should not really complain.
cheers
gary r
Re: TX
« Reply #5 on: April 09, 2007, 06:05:11 pm »
Gary, you have got me intrigued, you have fried a couple of speed controllers and now are you saying you have fried a TR as well in the same model?/or am I reading your topics on different threads wrongly.   Because, if you have fried 3 speed controllers and a TR, I think we may be looking at a serious fault here.   Also, what model are you fitting these speed controllers in.
John E
Bluebird
Aye
Re: TX
« Reply #6 on: April 09, 2007, 06:13:44 pm »
Hi John
I am pretty sure its his Scharnhorst.
Richard ;)
Youngat65
Re: TX
« Reply #7 on: April 09, 2007, 06:32:44 pm »
send for an electrician Gary
gary r uk
Re: TX
« Reply #8 on: April 09, 2007, 09:58:17 pm »
Hi Bluebird
no i have not cook a TX i seem to have to topics going at once.
my Scharnhorst has cooked 2 esc .
12 volt power all fused i don't know
gary r
Re: TX
« Reply #9 on: April 10, 2007, 08:21:14 am »
What motors are you running in her Gary?
gary r uk
Re: TX
« Reply #10 on: April 10, 2007, 09:14:27 am »
Hi Shipmate60
Scharnhorst is running a pair of direct drive fused 480's
gary r
Tug
Re: TX
« Reply #11 on: April 10, 2007, 07:13:25 pm »
? FUSED ?
and still fried the speed controllers?
I am confused. Tug
gary r uk
Re: TX
« Reply #12 on: April 10, 2007, 10:47:43 pm »
hi guys
free membership to the confused club
gary r
Peterm
  • Inactive
Re: TX
« Reply #13 on: April 11, 2007, 02:00:00 pm »
Gary, just picked up on this thread.   I expect it has all been said before, BUT, the best place for the fuse is in the power line, not the motor circuits, the esc current rating should be approx twice what the motor draws under normal running conditions, and fuse ratings should be about three quarters of the esc rating.   Hope this makes sense.   Pete M
I`m not just old, I`m ancient
bigH
Re: TX
« Reply #14 on: April 11, 2007, 02:36:45 pm »
 ???  Hi guys, I always read these threads because I' a dummy when it comes to electrics.   I have learnt somethings however and now I have just learnt how to be really confused..... bigH
gary r uk
Re: TX
« Reply #15 on: April 11, 2007, 02:48:57 pm »
bigh
your confused!
peterm
it runs from 12 volt battery to 20 amp fuse then 15 amp esc to power.
i ran it out of the ship on a 6 volt direct from the battery to the motor and put a meter on it & it was drawing 3.36 volts.
gary r
Peterm
  • Inactive
Re: TX
« Reply #16 on: April 11, 2007, 03:01:34 pm »
Gary, still trying to help.   The fuse rating is too high,  for a 15 amp esc, fuse should be no more than 10 Amp.   When testing motor, the most important factor is the amperage the motor draws, did you mean 3.6 volts or amps?   Pete M
Re: TX
« Reply #17 on: April 11, 2007, 03:04:31 pm »
I'm also confused. If you fuse the motors wont the power go through the esc before blowing the fuse ?
Richard ???
gary r uk
Re: TX
« Reply #18 on: April 11, 2007, 03:36:08 pm »
guys
from the 12 volt battery ---20amp fuse--- 15amp esc ---motor
tryed it today without the esc on a 6 volt & it pulled 3.36 VOLTS @the motor (1)
gary r
Tug
Re: TX
« Reply #19 on: April 11, 2007, 05:33:36 pm »
If the motor pulled the battery down to 3.6 volts then it is drawing a huge amount of the amp fella's,  [short?]
Peterm
  • Inactive
Re: TX
« Reply #20 on: April 11, 2007, 07:12:59 pm »
Gary, to see if the motor is drawing excessive current (Amps), connect your dvm in series between the battery and the motor.   On the meter use the 10 Amp and common connections.   If it goes over the top, the meter internal fuse should protect the meter.   Pete M
Re: TX
« Reply #21 on: April 11, 2007, 09:55:46 pm »
Gary,
2 problems.
The fuse should be less than the capacity of the speed controller to protect it.
You need the current drain of the motor(s).
As previously stated if it is pulling the battery down that far either the battery goosed or there is one big short in one or both the motors.
If the motors have been "cooked" the varnish around the armature windings can melt giving a dead short.
Try putting a continuity tester between the terminals and slowly turn the motor.
If you connect the leads together you will get a dead short reading, it should be 1 ohm or less, if motor shows this motor is goosed.
gary r uk
Re: TX
« Reply #22 on: April 12, 2007, 01:51:56 am »
Hi guys
many thanks for all your advice so far.
i went to maplins on the way to work last nite and got to new mfa 540 all new wiring and lower value fuse's  tomorrow i will connect them up to a 6volt and see what the reading is before going anywhere near another esc.
cheers
gary r
OMK
Re: TX
« Reply #23 on: April 13, 2007, 12:09:33 am »
I couldn't help a wee chuckle... Our colonial Stateside cousins would immediately know the answer to this one.
"R T F M"!
Re: TX
« Reply #24 on: April 13, 2007, 12:10:35 pm »
"R T F M"!
Been there, done that - still had to connect it all up and play to get the answer.  ???
Maybe Gary didn't have TFM
JMO
Doug
Page created in 0.186 seconds with 21 queries.
