Author Topic: Rudder Servo for Sea Queen  (Read 3855 times)
vk6tnc
« on: April 15, 2012, 10:14:52 am »
I have a Spektrum DX6i that came with a 6210 rx. What size servo would best suit the Aerokits Sea Queen. I get conflicting reports from my LHS's
Re: Rudder Servo for Sea Queen
« Reply #1 on: April 15, 2012, 12:49:17 pm »
I would say a standard sized meteal geared servo would be a good bet... Its what I'm planning on using in my Huntsman
Something like this one
http://cornwallmodelboats.co.uk/acatalog/futaba-servos.html
scroll down to the Futaba S3305 BBMG Heavy Duty Servo
or this
http://cornwallmodelboats.co.uk/acatalog/hitec-servos.html
Hitec HS645MG Servo
Im using the Futaba one in my Huntsman.  mainly as it was leftover from one of my helis
knoby
« Reply #2 on: April 15, 2012, 07:05:30 pm »
http://www.giantcod.co.uk/dys0213-metal-geared-standard-servo-p-402622.html
I use these in both my Marbleheads & they work really well, especially for the price
Glenn
The path of excess leads to the tower of knowledge
tugs62
« Reply #3 on: April 15, 2012, 07:45:58 pm »
i use a standard futarba one in my sea queen and never had any problems with it
« Reply #4 on: April 15, 2012, 08:05:22 pm »
aye aye there
I should imagine any standard servo, such as Futaba or HiTec would do the job.  This is because the Sea Queen isnt a really exceptionally large model with huge rudders.
The yacht lads might use them in their big yachts - cos some of the rudders on the yachts can be about 6 - 8 inches long - 3 - 4 inches wide.
Also, the power boat lads would use the metal - geared servos for their reliability - plus the amount of vibration which the servo in the power boats would encounter.
If if it was me - I would go for the bog standard servo - plastic gears, but, I would ensure that the servo is mounted correctly and there is no restriction in any movement such as 'tight spots' between the rudder linkage and servo.
I have had trouble with a servo which was my own doing, and this was cos I was converting the electric plug so that it would run on the old Sanwa set.  Then, after conversion the said same servo I plugged into a standard Futaba RX - needless to say it 'fried;  <:(  >>:-( >>:-(
aye
john
vk6tnc
« Reply #5 on: May 10, 2012, 10:59:55 am »
On the Jotika website they show a servo saver type of servo horn, anyone know where these are available or what have you used to couple the rudder to servo ?
Thanks in advance
Chris
« Reply #6 on: May 10, 2012, 11:25:09 am »
Have look on the toy car sellers sites for servo savers, not usually needed on a boat, saves the gears stripping when a wheel (?) bashes an obstruction.
« Reply #7 on: May 10, 2012, 09:38:26 pm »
Believe the LHS that says a standard servo will do the job.  let that one have your future custom.
« Reply #8 on: May 10, 2012, 11:34:22 pm »
Futaba 3003 allways does the job for me on mine,and it's been on for 5yrs with no probs at all
