Author Topic: Relay switch  (Read 3672 times)
Angus64
Relay switch
« on: April 23, 2012, 11:29:31 am »
Hi Boys. I'm here with another electronics question. I purchased a Omron 10A/16A electronic relay switch to switch my cooling pump on & off but the instructions are not very clear, Anyone out there had any experience with these switches,It has three terminals.i have added a couple of pictures hope it might help
Re: Relay switch
« Reply #1 on: April 23, 2012, 11:38:35 am »
I should imagine that one terminal is connected to another and switches to connect to the other when energised.
Re: Relay switch
« Reply #2 on: April 23, 2012, 11:58:42 am »
I would think it is +ve feed from battery, Common ground (-ve) and +ve switched power to device
Never seen one before so just taking a wild stab in the dark, so dont ask me which is which lol
Angus64
Re: Relay switch
« Reply #3 on: April 23, 2012, 12:43:08 pm »
Hi Boys .Thanks for trying, I found a bit of info on this switch, does this help. Can you tell me where the wires go from that diagram
   Angus.
Re: Relay switch
« Reply #4 on: April 23, 2012, 12:44:05 pm »
It could be power feed to centre, and a normally open and normally closed terminal on either side.
A multimeter will tell you all you need to know.
Re: Relay switch
« Reply #5 on: April 23, 2012, 12:46:11 pm »
   Angus.
Just beat me to it  :} :}
petermun
Re: Relay switch
« Reply #6 on: April 23, 2012, 03:12:59 pm »
From the diagram, the normally open (n/o) contact of the switch is connected to the positive side of the power supply, the normally closed (n/c) contact is connected to the circuit, but has no power supply.   The centre common (c) contact moves to n/o when the relay is activated by the receiver output, and supplies power to the circuit through the load.   Pete
Re: Relay switch
« Reply #7 on: April 23, 2012, 03:43:32 pm »
What they said - I would just add that if following that diagram, the fuse really needs to be in the battery +ve supply so that the rest of  the model is protected.  Where it is, the only thing being protected is the relay contact, and that against the possibility of a shorted lamp.
Angus64
Re: Relay switch
« Reply #8 on: April 24, 2012, 10:13:20 am »
Thanks for the advice Boys, I took the switch into the local auto electrician this morning & he told me the same as Pete, Spot on mate thanks. I try & get it fitted tomorrow & let you know how I go.
      Angus.
Angus64
Re: Relay switch
« Reply #9 on: April 25, 2012, 08:08:35 am »
Hi Boys. I fitted my Omron relay switch today, worked like a charm, I will try it out on the water when the weather get's a bit warmer.
    Angus.
Page created in 0.025 seconds with 23 queries.
