HMS Polyphemus (1881), Pillars & FramesTo me detailing is the most enjoyable, although sometimes frustrating, part of any build. I am in awe of some of the scale ships I see, but happy if I can do my best whilst hopefully improving.
Pillars 28 flying deck support pillars made up with boss and plate each end. I had intended to make the flying decks removable, but there is too much detail between upper and lower decks, and even across decks, which meant this was not practical. So, the external Piezo bilge alarm had to be relocated from under the flying deck to inside, under the funnel.
With all flying decks glued in place the pillars could now be fitted. This would also allow the float off raft structures and inter deck walkways to be fitted more solidly.
Support pillarsLife Raft handling frames With the arrival of the two Shapeways life rafts I could start on the launching frameworks.
These each have a boat supporting frame operated by helm-type wheels via gears to tilt the frame down towards either beam. Alternatively the boats could be released in situ to float off if required.
The amount of Plastruct extrusions consumed has been considerable.
No, I am not going to make working versions !
First I made up the four vertical framework assemblies, slotting the main tubes for the horizontal jacking bars. Next I constructed the two boat support frames, which slot into the bars.
Currently making up the hand-windlass assemblies between the deck sections, gear & shaft drives, not quite finished yet.
Life raft framesAs I would be using tarpaulins I did not require interior detail on the boats. Cheaper to 3D model.
The other 4 boats are from Quaycraft. More on the boats next time.
Planning well ahead, the potential vulnerabilities of much hull-overhanging detail will make lake side handling extremely delicate. It may need a special launching frame / straps to protect detail, life boats, prop shafts and bow rudders. All part of the challenge.
